What year 5-speed trans will fit into an '03
Old May 7, 2013 | 10:40 AM
EVOEvolved's Avatar
I was curious if a '05 GSR 5-speed transmission would fit into my '03 GSR. Any t-case differences for lining up or?
Old May 7, 2013 | 12:15 PM
evolve_VIII's Avatar
I believe thay are all the same. Just the T-case has ACD on the newer evos
Old May 7, 2013 | 12:26 PM
Ev0ikon's Avatar
There are slight gear size differences but they do bolt right up. Ditto for transfer case.
Old May 7, 2013 | 12:41 PM
EVOEvolved's Avatar
'Ahh good I wanted to make sure before making the purcahse!
Old May 10, 2013 | 03:13 PM
EVOEvolved's Avatar
I looked up the '03 and '05 Evo GSR's 5-speed and the gear are all the same for every gear including the final.
Old May 10, 2013 | 06:38 PM
djdnav's Avatar
All 5spd 8-9 trans are the same fitting wise, as stated. 8-9 have different (1,3,5) gearing iirc. Also the 03 had an open center diff
Old May 10, 2013 | 08:08 PM
EVOEvolved's Avatar
The 2006-'s 5th gear is slightly different that is it.
2003:
2004:
2005:
2006:
evo8vz
Oct 16, 2016 05:18 PM
Paulevo9
Oct 28, 2015 08:51 PM
TopLevelPerformance
Aug 15, 2014 02:40 PM
evox23
Jun 2, 2014 01:09 PM
