loud noise car dies??
Old Nov 23, 2007 | 05:38 AM
haloevolution45's Avatar
Unhappy loud noise car dies??
Ok i have a slight problem and have no idea what it could be. lets say im sitting at a red light at idle, and there is a truck next to me with exhaust or somethin. and it starts to go. tho noise/ vibration will either cause my car to bog down or even die? it also bogs down if i just drop my hood at idle? has no check engine light either... any ideas? thanks...
Old Nov 23, 2007 | 05:45 AM
TeStUdO's Avatar
Thats just the nature of a MAF equipped car. Do you run an open air filter? That usually makes it a little worse.
Old Nov 23, 2007 | 05:47 AM
ya i do i have the hks suction filter but it never did it when i first got it and my buddy has the same intake and his car doesnt do it?
Old Nov 23, 2007 | 05:48 AM
Dropspeed's Avatar
I have never heard that in my life?
So you are saying a loud noise will cause a MAF equipped car will die at a light from a lound noise/vibration?
Anything to back that up?
Matt
Old Nov 23, 2007 | 05:49 AM
rcheung's Avatar
its our overly sensitive knock sensor. Its normal
TeStUdO's Avatar
Do you have cams? Does he? The tune has alot to do with it too. Your timing at idle or maf re-scaling can affect it.
Old Nov 23, 2007 | 06:03 AM
alicea8541's Avatar
Mine too, it's your knock sensor freaking out like rcheung said above.
Old Nov 23, 2007 | 06:05 AM
no i dont have cams but i do have a really messed up tune by cobb. my car runs like crap ( not like daily driving though just when you decide to get on it it cuts out at 5500). i was thinkin maybe the knock sensor too but wouldnt it throw a code if so and i logged it and got no knock when it does such things...
Old Nov 23, 2007 | 06:06 AM
TeStUdO's Avatar
Originally Posted by haloevolution45
no i dont have cams but i do have a really messed up tune by cobb. my car runs like crap ( not like daily driving though just when you decide to get on it it cuts out at 5500). i was thinkin maybe the knock sensor too but it would throw a check engine if it was bad and the knock sensor is not sensitive enough to do that if so a stock evo with no problems would do it.
If your knock sensor sees more than ~3 counts of knock it will just dip into the low octane map. The car wont throw a CEL.
Old Nov 23, 2007 | 06:07 AM
saiyanzzrage's Avatar
mine does that all the time if a harley or truck is next to me, or even if i close the hood of the car when its on. its the ecu thinking it hears knock. Its kinda annooying, almost as if the car is acting scared and wussing out lol
Old Nov 23, 2007 | 06:08 AM
dubbleugly01's Avatar
you are not alone.... several evom members have had issue with loud cars next them, or harley's or whatever making their car die. I wouldn't call it a common issue, but it is an issue with several cars. Several threads on evom about this to research.
Old Nov 23, 2007 | 06:17 AM
huh thats weird though car never did it before and i have had it for two years. just weird it comes out of the blue. well my car went to crap after trying to get it tuned ran fine before hand
Old Nov 23, 2007 | 07:10 AM
speedytl's Avatar
when i'm at the track next to a loud @ss hot rod it dose this but it dosen't stall
Old Nov 23, 2007 | 07:43 AM
cfdfireman1's Avatar
Knock sensor, my car will even stumbles a bit when you close the hood if it's running. Very noticeable at the track for sure.
Old Nov 23, 2007 | 07:49 AM
smokedmustang's Avatar
Normal. Mine did it also. It is the computer and the knock sensor doing their job.
