SD cold start issue?
Old May 7, 2013 | 06:16 PM
bnr34rb26dett's Avatar
Im thinking about going SD with TS Comp tune.
However, I am still debating on my options.
I have been hearing mostly positive things but I would like to know how cold start up is for people. does the car start in 20f weather? do you have to wait till the car is fully warmed up to drive it?
any opinions would be appreciated.
Old May 7, 2013 | 06:24 PM
Frew's Avatar
Nope toms sd is spot on
Old May 7, 2013 | 07:34 PM
PureDrivePerformance's Avatar
Hope this helps your decision.
Old May 7, 2013 | 08:58 PM
is there any downside to going SD? lol
Old May 7, 2013 | 10:06 PM
BluEVOIX's Avatar
Only problem I had with SD and cold startup was high idle. It would idle at 2k rpms, then slowly come down as the car warmed up until resting at set target idle.
Old May 7, 2013 | 10:28 PM
Are you back on maf?
I had a customer with idle issues like that and I was able to tune it out.
If your still on SD I can take a look.
Old May 7, 2013 | 10:33 PM
I can't think of any downside. I don't know if a MAF is needed for a visual inspection at emissions.
Old May 7, 2013 | 10:36 PM
211Ratsbud's Avatar
I was able to self tune, at moderate novice level every quirk typical sd starters encounter, on a less than popular rom. I drove it all winter in NNY -20,-30 at times during start up, and now that the weather is warmer, its just as well.
Its not as bad, and is becoming more and more commonplace.
Old May 9, 2013 | 09:17 AM
well it sounds like im goind SD for sure then lol
Old May 9, 2013 | 07:40 PM
BluEVOIX's Avatar
Thanks, but I actually sold the car. It would only idle high when the car was completely cold. I tried to look at the ISCV table but with SD roms the values didnt show or allowed for editing. I know tephra v7 maf allowed adjustment of those values but the v7 SD didnt.
Old May 10, 2013 | 06:17 AM
ReignMan24's Avatar
I will guarantee you if you go with TSComp you will not be disppointed. Tom's SD tunes have to be close to the best out there. I just had S3's installed with springs and retainers on stock bottom end and within 3 roms top had driveability and idle spot on. Reason I know he's one of the best is, I made the mistake a few months back and switched tuners, and ended up with terrible driveablity. Went back to Tom immediately.
Old May 10, 2013 | 08:28 AM
< Gets it done in 4 ROMs in less than 30 minutes.
I'm bench racing tunes. JK!
Tom is definitely one of the best, as well as Aaron at ER, Jamie at DynoTech, etc. All these guys I look up to and I'm working my tail off to get mentioned in the same breath as them.
You won't be disappointed with any of us. GL.
Old May 10, 2013 | 02:20 PM
ReignMan24's Avatar
^^ I'm sure u guys r good as well, sumthin I noticed tho when I strayed away from Tom like an idiot was, a decent amount of tuners did speed density but couldn't do remote SD, so i'm sure if yall get that down, im sure ull do very well
Old May 10, 2013 | 02:25 PM
Great point! I remote access their computer so I can adjust immediately.
Old May 10, 2013 | 02:46 PM
ReignMan24's Avatar
^^I'm sure yall will do well, and to the OP, SD is definitely the way to go, so GL
kpr
14
Apr 24, 2024 12:42 PM
TheBigD
10
Jan 2, 2015 09:27 AM
06Black
Feb 22, 2012 01:13 PM
aka.ralliart15
84
Jan 28, 2011 04:06 PM
BEISSEN
Jan 20, 2011 10:40 PM
