Possible Fuel Pump problem!
Old May 10, 2013 | 06:10 PM
krazirob's Avatar
So today I went to take off out of a parking lot and when I hit 3rd gear at about 50% load a loud pop noise and so i threw it in nuetral and coasting into another parking lot. Sat there and idled and it idled perfectly fine. As soon as I hit the gas pedal it falls flat on its face at about 2-3k rpm. If i push the gas and let go repeatedly very fast going further and further it revs fine. But if i slam the gas pedal down it stops at about 4k and stays there but sounds like it falls flat on its face and sputtered's. As soon as I lift off the gas the rpms drop down to about 2-400 rpms but then 2 seconds later or so it goes back to normal rpm range for idle. Im thinking its fuel pump. I checked plugs and those are fine and coils are good also. No vacuum leaks and no fuel leaks. All air intake and IC piping is in tack and not leaking. I would think its not injectors because for one I doubt all 4 would go out at once and if one was out it would sound messed up at idle. Also IF ALL 4 were messed up i wouldnt think it would idle at all. I pulled pump out and the filter is nasty. All lines that i disconnected had fuel in it also.
Any help would be appreciated. Im currently a couple states away from home so gonna get a new pump and hope this is the issue.
P.S. oh and also pump has no noticeable whine and it primes when key is turned.
Old May 10, 2013 | 06:11 PM
krazirob's Avatar
by the way no code is popping up either.
Old May 10, 2013 | 07:29 PM
hiboost2.0's Avatar
Is it misfiring? If you have evoscan and believe it's a fuel pump problem try to prime the pump with evoscan, remove the high pressure line and put another hose on the fuel pump housing leading into a bottle that can contain about 20oz, prime the pump.
Old May 10, 2013 | 07:49 PM
krazirob's Avatar
It's not misfiring. Data logged it and looked fine. Just took pump out and cleaned out filter and it ran good for about 5 min. Then went back to what it was doing earlier. Which leads me to believe its def pump and filter issue. It's a stock pump with 55k. Just picked up this evo recently. It's my second one so know my way around it pretty good.
Here is a question though. If pump does not make any noise at all will it still start and idle?
mnewdigate
Lancer Troubleshooting
10
Apr 24, 2016 11:25 AM
BOOSTINAT30PSI
64
Dec 8, 2011 09:39 AM
bigben
Jun 28, 2010 06:41 AM
haloevolution45
10
Oct 2, 2007 02:25 PM
