Low idle and stalling
Old Mar 1, 2012 | 06:08 PM
mnewdigate's Avatar
Hello everyone! I just picked up a 2003 Lancer OZ rally edition from a friend. A mechanic recently replaced timing belt, water pump, plugs and had the head redone as the previous person had the timing belt snap. At first it would idle when warm around 400 at a stop and almost like a miss, but did not stall. I put some gas in it and it seemed to have a bit of trouble starting and while cranking I had to press the gas pedal a bit to get it to start. It still had a bit of a starting issue, but would start on its own without hitting the gas pedal. If I was driving at any speed and let off the gas to coast the idle would drop to around 1000 then go back and forth from there to 1500.
Today I did an interior detail and changed some lights out. While doing that I had the battery unhooked. I put the battery back in and it started fine and held idle fine. When I was driving at a speed around 35-40 and would let off the gas the idle would drop below 400 and try to stall, which it might have had I not tapped the gas pedal. At every stop the idle drops all the way until it stalls. It will stay running if I hold the gas pedal. After I put the battery back in I started the car for about five minutes and then drove off. I am not currently seeing any CEL lights at all, but then again that light might not work. I have been searching and found a few things that I can try tomorrow to try and pinpoint the issue including:
  • Clean throttle bottles
  • Vacuum leaks
  • MAS
  • IAC (Wow pricey part!)
  • Throttle cable
The car when driving seems to me to drive fine as long as I am pushing the gas pedal. Currently it has 80k miles on it. Any other thoughts of what I might check? Thanks for any help!
Old Mar 21, 2012 | 01:26 PM
PaulNuspl's Avatar
have you figured out the problem? i drive a 2002 mitsubishi lancer and the same thing is happeneing. please help. im clueless!
Old Apr 18, 2012 | 12:51 PM
bostssgt's Avatar
check for vacuum leaks around injector seals on the head (shoot brake cleaner on it and watch for stumble)
Old May 14, 2012 | 10:39 AM
PaulNuspl's Avatar
still havent figured out the problem. it runs for now but idles high because i adjusted the throttle cable so it wont keep dieing one me when i stop lol but now wheneveer i idle it makes a popping/crackling noise under the hood kinda by the steering wheel area. i dont know what it could be amd im too broke to go to the shop
Old May 28, 2012 | 12:36 PM
XLancer06X's Avatar
Im having the issue of my car idling below 500 RPM's as well and its dieing I just replaced my TPS and my IAC is there a certain way to install the TPS sensor??
Old May 28, 2012 | 03:39 PM
03lances's Avatar
As already suggested check for any vacuum leaks. Also It would be a good idea to clean your maf and your throttle body/intake manifold too as that seems to cause the low idle/stalling alot too.
Old May 28, 2012 | 03:55 PM
azyan's Avatar
I had this issue a long time ago. I replaced the oil switch and the rpm went back to normal. The oil switch is cheap and you can change it out yourself. Its worth a shot.
Old Mar 19, 2016 | 11:16 AM
Bmatwie's Avatar
Low idle and stalling SOLVED
Hi guys,
I see that lots of you are have the low idle and stalling issue. I'm a Mitsubishi mechanic and the most common reasons this issue happens is either one of 2 things. First, it could be a dirty or faulty IAC valve. Check and replace if necessary.
The second most common problem is the introduction of air into the cooling system. I know most of you will say the cooling system has nothing to do with rough idle, but trust me, it does.
To fix the problem, simply open the rad cap, start your car and let it idle for 15 minutes with the rad cap off. This will get rid of the air bubbles in your coolant and smooth out your idle. This should fix most of your rough idle and stalling issues.
Old Mar 21, 2016 | 07:23 AM
mcgarvey's Avatar
What he said above. When the ECT sensor sees an air bubble rather than hot water, the computer erroneously adjusts the fuel mixture. The result is an unstable engine speed.
Old Mar 28, 2016 | 11:39 PM
CrAnSwIcK's Avatar
For future reference the OP's first post symptoms are typical of an evaporative emissions purge solenoid being stuck open...
Old Apr 24, 2016 | 11:25 AM
Junetoocraybugg's Avatar
Rough idle and my oz rally wont start
So basically i just brought a 2003 Mitsubishi lancer oz rally. When i got it it only needed a new timing belt and kit. Ended up installing that and a new starter, new battery, new sparlk plugs, air filter, throttle body positioning sensor and crank shaft sensor. I got the car running but with a major flaw, the engine shuts off when i come to a stop or if i slow down to where the rpm goes below 1 it will shut down. So i let the car sit for bit untill i could figure it out but a couple days i go to start the car and nothing. I've talked to a couple mechanics but no luck. It cranks and pulls over but just doesnt want to start. Any tips or suggestions i could try to get this thing running? Im low on cash so prefabaly things that dont involve me going flat broke.
TurboTylerIX
21
Dec 19, 2017 11:16 AM
Zer0_13
Aug 6, 2017 04:27 PM
Evo1001
May 30, 2017 06:42 PM
najo
14
Dec 30, 2016 07:46 AM
GaminKWB
Lancer Engine Management / Tuning Forums
15
Oct 21, 2016 03:48 PM
