Brian Crower springs and titanium plates
Old May 13, 2013 | 02:03 PM
KOOLER's Avatar
Gentlemen,
willing to throw in GSC S2 cams. Now I run BC272 cams installed by previous owner (I know they are crap so looking for swap). I also run BC springs and Ti plates. Heard BC springs do crack... Should I keep them now or should I replace them with... GSC springs? Tomei springs?
Thanks!
Anton
Old May 13, 2013 | 11:52 PM
Thore's Avatar
I wouldn't want a valve spring to crack with my brand new GSC S2's in the same room. Just hold off on installing the cams and do it all at once.
Old May 14, 2013 | 03:10 AM
KOOLER's Avatar
What springs should I use in this case? Tomei?
Old May 14, 2013 | 07:48 AM
Travis@GSC's Avatar
i would stick with a beehive style spring, we offer 2 sets, hi boost and low boost. They include springs and Titanium retainers.
Old May 14, 2013 | 08:31 AM
KOOLER's Avatar
What would you recommend for your S2 cams? I run 1.8 bar normally.
BTW, do you make your own ones or OEM something?
Old May 14, 2013 | 08:58 AM
dastallion951's Avatar
Just run the Springs n retainers I'm running same, they've been in my car for past 50k, on hks 272 for 20k and s2s for over 30k without a problem.
Old May 14, 2013 | 09:13 AM
KOOLER's Avatar
Will your S2 cams work with Tomei springs fine?
KOOLER's Avatar
you mean existing BC I have?
Old May 14, 2013 | 10:25 AM
Travis@GSC's Avatar
From what I know about the Tomei springs, which isnt much, is that they require the EVO 7 steel retainers. They are a non beehive spring, so the steel retainer will be heavy. I wouldn't recommend it.
If you were to go with a GSC spring kit, I would say the low boost 5040 kit would be fine. But you may be fine with the BCs
foxbat
Jul 10, 2016 07:35 AM
740 Turbo Brick
Nov 8, 2015 12:24 PM
03black8gsr
Apr 14, 2012 10:46 PM
PhantomBlackEVOX
24
Feb 15, 2011 03:14 AM
Paul Nelson
72
Oct 31, 2007 07:42 PM
