HELP! need to identify these connectors
Whelp, this is a little embarrassing. I took of my Intake Mani a while ago, in doing so I unplugged a few sensors. I went and installed everything today and have 2 sensor connectors (or whatever type of connector they are) that I don’t have anywhere to plug them into. I’m ASSUMING that these plugs connected to A.C system that used to be in the car (it was removed) but just wanted to confirm. I spent ½ hour looking for any connections in that area I may have missed, but nothing.
I was hoping someone might confirm that I don’t need these hooked up to start the car….
Yep. B122 and B124. Ignition coil and FPR solenoid.
Your car WON'T start with the second coil unplugged, as you will be down 2 cylinders. I assume since the FPR solenoid isn't on the manifold anymore that you or a prior owner deleted it. I also see an AMS rail feeding an aftermarket FPR......you probably won't throw a code for the solenoid being unplugged as I am also assuming the car is/was tuned.
FS[Northeast]: 2008 Phantom Black Lancer Evolution GSR (Central NJ)
artnsx
For Sale - Cars For Sale
Oct 22, 2014 06:05 AM
EvoLeoIX
64
Feb 8, 2014 07:45 PM
jason42003
Jan 20, 2014 12:34 PM
foxbear2277
Dec 15, 2013 05:49 PM
