Trouble Holding Base Idle (Dips Below 850) When Going From 1st or 2nd Gear to Neutral
I do a lot of idle only tuning. You can go to my website for more info. You can also do it yourself. There is a plethora of information on here. You just have to read, read, read, test, then read some more.
I know this is an old thread but you guys with idle issues might want to swap back out to the stock rubber intake if you are running aftermarket intake tubes and such. I had idle dipping issues and rich swings at low rpm cursing. I scaled the MAF after my JM Fab intake install and it didn't matter. I changed the IAC, plugs, cop kit install, new cone filter, new injectors(I was gonna swap em anyway) new fuelab FPR, nothing fixed it. Then last night I said F this and threw my stock rubber intake hose back on and no more idle dip and running straight stoich 14.7 at idle and cruising. Running like a dream.
randomevo
Dec 18, 2016 11:11 AM
VtexGt3
22
Oct 9, 2016 08:11 AM
Jamesm331
Feb 29, 2012 08:32 AM
blaze_125
Lancer Troubleshooting
Dec 2, 2011 09:52 AM
