Rear end Clunk when shifting hard
Old Nov 30, 2013 | 08:58 PM
Simmons's Avatar
I have noticed that when I am shifting hard (letting the clutch out much faster than casual) I hear a loud clunk coming from the rear end. I have recently changed the transmission fluid with Redline, changed the rear diff fluid with Lucas LSD fluid @ 90K miles. I recall it making the sound before the fluid changes so I know it did not have an effect on the noise. I am assuming it is play in the drive shaft U joint to the rear diff. Is there any way of telling how much play is too much. When I was last under the car I could twist the drive shaft by hand and get about 1/4-1/3" of rotation. Is this sound normal or should I be looking into replacing the U joints?
Thanks
Old Nov 30, 2013 | 09:22 PM
jason42003's Avatar
It's normal for these cars, one way to reduce it is to replace your rear differential bushings and mustache bar bushings with stiffer ones. replacing the engine mounts and the driveshaft carrier bushings will also help a bit.
Old Dec 5, 2013 | 09:16 AM
soderdna's Avatar
This is it. The factory bushings are soft for comfort and keeping noise down. Replacing the diff carrier bushings help the most than replace the rest to really hold down the rear end. Expect some noise to become audible after the bushing install. It's not your rear diff committing suicide haha its just the vibrations being transferred to the frame in the form of whine.
Old Dec 5, 2013 | 09:51 AM
David Buschur's Avatar
Could be the rear diff gears but typically you will get whine when driving. The rear control arm bushings, mustache bar and side diff supports can all be swapped out and it will eliminate the rear end moving, make it more durable and get rid of the clunking noises.
Old Dec 5, 2013 | 11:31 AM
soderdna's Avatar
Haha I love that David still comes on here to drop knowledge on us. Correct me if I'm wrong but I believe you guys still offer the lightest rear diff carrier option available?
Old Dec 5, 2013 | 12:29 PM
jason42003's Avatar
I think it's the only one now ams doesn't seem to be making their version anymore. At least it wasn't on their site last I checked couple weeks ago and lancershop isn't carrying it anymore either.
Old Dec 5, 2013 | 01:14 PM
Ev0ikon's Avatar
driveshaft carrier bushings/Propeller Shaft Mt. Bushings
https://www.evolutionm.net/forums/ev...-beatrush.html
Old Dec 5, 2013 | 01:37 PM
justboosted02's Avatar
dont worry about it.... BEAT THAT GTR!
Old Dec 5, 2013 | 01:40 PM
Ev0ikon's Avatar
Funny or not, I go the fastest when I get the "clunk" on the shift.
Old Dec 6, 2013 | 06:22 AM
Yes, we still offer the billet side diff supports, aluminum and the mustache bar we always have. They are good sellers actually, we have no plans to stop doing any EVO stuff!!
Old Dec 6, 2013 | 11:16 AM
jason42003's Avatar
Good, gotta get your setup sometime only thing stopping me now is the price, but hey gotta pay to play the game and buschur parts are worth the money.
Old Dec 6, 2013 | 05:05 PM
egis's Avatar
Like somebody says before:if you don't hear clunk you don't shift hard enough lol
Old Dec 7, 2013 | 07:51 AM
jrainwater's Avatar
I got sick of that clunking noise and replaced the diff supports. The ones he sells actually. Never made another noise again. I also did the driveshaft carrier supports at the same time but I know it was the diff supports making that noise.
jdogstoll23
May 9, 2016 09:34 AM
evo8mr04
Oct 7, 2015 06:50 PM
dillon410021
Sep 27, 2014 07:55 PM
npham455
May 8, 2012 09:18 AM
sesso
17
Jun 16, 2006 02:16 PM
