Clunk noise when turning
Old Oct 6, 2015 | 05:19 AM
evo8mr04's Avatar
Hi,
I'm new to evos and to this forum.
I have an evo8mr and recently at heavy traffic stop light, I stalled my car and panic with the traffic behind me waiting, I stupidly accelerated too much on 1st gear turning right and the outcome now is I hear clunking noise on the rear when I turned right from 1st gear on normal take off. My exedy cluth is new and can smell it after the incident.
I read here that the noise could be coming from the:
ayc
cv shaft/joint
wheel bearing
check cv couplers
axle
clutch
require fluids change
The noise is only heard on 1st gear with acceleration but I dont hear the noise on straight or left turns.
HELP!
Thanks
Old Oct 6, 2015 | 02:19 PM
evo8mr04's Avatar
Bump
Old Oct 6, 2015 | 02:39 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Could be loose suspension components
Mustache bar
Springs coming loose and slapping against the top-hats
Rear diff chatter
Worn out bushings
Do you have any suspension mods?
Old Oct 6, 2015 | 04:38 PM
evo8mr04's Avatar
Thanks golgo13.
My springs are slightly lowered with stock suspension.
The noise is a slow tick, tick and gets faster when I put more power from 1st gear turning right.
Tick...... tick..... tick... tick.. tick. tick. tick.
I'm more worried that I broke something on the AYC rear diff.
Old Oct 6, 2015 | 04:49 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Have a friend sit in the back of the car with a stethoscope and try to localize the sound while driving.
Once you know where it's coming from, you can probably start looking in that area. If it's not coming from the center of the car, it might be a wheel bearing or a brake rotor heatshield or who knows?
Old Oct 6, 2015 | 07:43 PM
evo8mr04's Avatar
Thanks golgo13. Ill check it out.
Cheers
Old Oct 7, 2015 | 05:53 AM
CaptainSquirts's Avatar
Jack the car up and see if there is any play on the wheel. I am having a thumping sound coming from my front right when I turn left. Jacked my car up and the front right has play on it.
Old Oct 7, 2015 | 09:43 AM
cquencebrakes's Avatar
CV Shaft/Joint if this is really the case. Check to see if the boots are torn.
Old Oct 7, 2015 | 06:50 PM
evo8mr04's Avatar
Ill check em out with my mechanic next week.
Thanks ppl.
nine3shoof
Jul 12, 2013 05:46 AM
WinglessWarrior
Apr 28, 2010 08:46 PM
guapoholic
Mar 1, 2009 02:28 PM
YEVOVIII
May 11, 2005 06:51 AM
umiami80
20
Feb 28, 2005 02:50 PM
