Evo v randomly pulling to either side
Old May 18, 2013 | 02:28 AM
craigybaby37's Avatar
Hi everyone I have asked this question on mlr but figured it wouldn't hurt to ask on here aswel.
Last weekend my evo 5 started playing up about a mile from my house, it started by pulling from one side to the other then stopped.......a little way down the road and again it pulls randomly to one side of one to the other.
Got home and I have since checked every suspension arm for breakages, all the bolts are tight on everything, no worn bushes as they are all poly bushed front and rear within the last 4 months.
CV joints on all driveshafts are fine, wheel bearings are all good frot and rear, track rod end are fine, ball joint all fine and all wheel bolts tight to my torque setting I use
When the problem occurres there is a rotational squeeking/whining which narrows int down I think to what it could be.
Power steering pump possibly failing losing pressure to the steering rack causing the car to randomly pull to one side, front diff failing and is on its way out?
I also have a failed rear abs sensor and it does bring on the ayc light occasionally maybe this could be caUsing problems like applying a brake somewhere causing the car to pull to the side?
Any help will be reaLy appreciated guys
Live4Redline
27
Apr 14, 2018 04:13 PM
deeman101
Oct 27, 2014 11:28 PM
Jameson_IXMR
Jan 23, 2013 12:27 PM
fireroasted
Jan 4, 2013 08:23 PM
proverb
Lancer How Tos / Installations
Sep 24, 2007 11:38 AM
