Is this retarded using an GSC2 Intake cam with a Kelford 272 Exhaust
Old May 29, 2013 | 08:54 PM
JDM EVO 6's Avatar
happened to have 1 of each lying around....both are simular....
Old May 29, 2013 | 10:29 PM
Thore's Avatar
I have absolutely no experience in this but, while you wait for an answer, you could look up the lift and duration or other specs for similarities.
Old May 30, 2013 | 05:26 AM
TommiM's Avatar
Nothing wrong since you already have one of each. Obviously the specs of each brand will be different, but if you know that's the duration and lift you want for the intake and exhaust, and you know that's the setup you want then sure. I don't know their specs off hand but Im sure they are similar enough anyhow.
Old May 30, 2013 | 08:29 AM
JDM EVO 6's Avatar
gsc are 11.2 kel are 11
Old May 30, 2013 | 11:21 AM
Travis@GSC's Avatar
would it be ideal? No
but it would absolutely work, and i dont think you will really notice much of a difference. You will still see nice gains.
Old May 30, 2013 | 01:54 PM
MechTech's Avatar
This.
How did you end up with one of each? lol
Old May 30, 2013 | 03:19 PM
Craig King's Avatar
Make sure to add some sugur to the gas tank before starting it.
Old May 30, 2013 | 03:53 PM
TommiM's Avatar
This....
Old May 30, 2013 | 06:35 PM
michaelrc51's Avatar
Originally Posted by MechTech
This.
Old May 31, 2013 | 12:43 PM
blackenedwings's Avatar
Props to you Travis for an honest answer. I know a lot of companies would just insist to the customer to buy the second cam for their brand.
That being said, exactly for that honesty, and for all the positive feedback the GSC cams get on this forum, if the OP is going to do cams, why not just spring for the second matching GSC cam and do it right the first time?
Old May 31, 2013 | 12:55 PM
adriano_917's Avatar
Sugar doesn't dissolve on fuel, it'll clog the strainer or an injector though.
Old May 31, 2013 | 01:49 PM
SWOLN's Avatar
^^^Only in Texas.^^^
kpt6
17
Jul 31, 2013 01:14 PM
