dailey driver clutch
Old May 28, 2013 | 11:15 AM
Tehjoser's Avatar
Unhappy dailey driver clutch
hi new to this forum]
i just bought a 2005 evo mr with 90k miles
i have lots of questions and hopefully u guys can help me
first question; the car revs up when in gear i feel like the clutch is slipping. it revs high then it feels like it catches and takes of dont know if it is cause the turbo is spooling or the clutch is going bad please help!!!
Old May 28, 2013 | 01:05 PM
llDemonll's Avatar
get on the freeway, put the car in 5th gear going 60-65mph, floor it
you'll know if the clutch slips
Old May 28, 2013 | 01:15 PM
trubo's Avatar
X2, although this can make even a working clutch slip in an awd car lol
Old May 28, 2013 | 02:05 PM
wjamyers's Avatar
exedy stage 1 holding 400 HP with no issues.
Old May 28, 2013 | 02:18 PM
Tehjoser's Avatar
It mostly slips when I hit the gas but I was messing with my clutch pedal and It releases within an inch of touching it,could that also be an issue??...
And also it's going to be my daily driver for now what type of clutch should I get? Stage 1 or 2?
Old May 28, 2013 | 02:26 PM
llDemonll's Avatar
stg 1 stg 2 stg3 etc depend completely on what type / brand of clutch you get. dont buy a clutch based off "stages", but it based off what power it holds and what you needs are.
Old May 28, 2013 | 02:43 PM
Tehjoser's Avatar
Well I want it mostly for everyday driving and a good pull if i ever decide to launch it.. I don't need a clutch that would be classified for racing
Old May 28, 2013 | 06:45 PM
Piro Fyre's Avatar
Pretty much a street clutch. A Competition Clutch stage 2, Exedy stage 1, or an ACT HDSS.
Old May 28, 2013 | 08:49 PM
tiggeryellow1's Avatar
Veteran: Army
ACT seems to be a pretty popular amongst the community.
Old May 29, 2013 | 09:59 AM
Thore's Avatar
I've had pretty good luck with the HDSS for the past 2 years. Isn't overly aggressive but will hold a decent about of power. Comp stage 2 would have been another consideration.
Stick with the OEM flywheel or something of similar weight. Trying to DD with a lighten flywheel gets old real quick.
Old May 29, 2013 | 12:34 PM
Tehjoser's Avatar
Ok so I decided to tweak with my clutch pedal I rotated the shaft counter clockwise and it seems that the clutch is not slipping as much now it still smells like the clutch is burning though any suggestions???
Old May 29, 2013 | 01:50 PM
barneyb's Avatar
If you can't get it to stop slipping by adjusting it is clutch time.
If you are stock or near stock and can control your impulses, a stocker works fine. I have 85K on mine.
Old May 29, 2013 | 01:55 PM
donzilla2004's Avatar
If the clutch plate material is worn out no amount of adjustment will help it, nor should you have to mess with the pedal, moving the shaft on the pedal only adjust the pedal not the actual clutch.
Old May 29, 2013 | 01:56 PM
ReaperX's Avatar
An oem replacement will work just fine. If you want something aftermarket I'd go with an Exedy Stg 1. I would not recommend any ACT product. If you can have the flywheel resurfaced go with that, if not a lightweight flywheel is not difficult at all to DD.
Old May 29, 2013 | 09:37 PM
Tehjoser's Avatar
Well guess it is time for a new clutch, I'm leaning more towards the exedy stage1... Thanks guys
