poncam type r 270 cams
Old Jun 1, 2013 | 12:37 AM
IGGZ's Avatar
If you have these on could you please share your impressions? Thank you.
Old Jun 1, 2013 | 03:22 AM
EvocentriK's Avatar
I have run them, I liked them. I found idle was too choppy for me and changed them out, but when driving they are solid, good spool good midrange and topend, gained ~20kw peak from cams alone. I'm not really a cams person they tend to annoy me so take my opinion with a grain of salt.
Old Jun 1, 2013 | 09:12 AM
JDM EVO 6's Avatar
Spoke to mike at awd and these cams are the best for e9 stock frame evo
I just wasnt ready to invest on springs
Old Jun 1, 2013 | 09:28 AM
TommiM's Avatar
I have the poncams type Rs going in my engine. Car isn't finished yet so no comparisons, but the specs seem to fit my bill pretty well. Mine is for evo8
IIRC stock springs is ok on these, but upgraded recommended.
Old Jun 1, 2013 | 11:04 AM
EvocentriK's Avatar
They ran fine with stock springs. I have <40K miles on my car though.
Old Jun 1, 2013 | 12:16 PM
okevolutionVIII's Avatar
Poncam or Procams? There is a huge difference in lift.
Old Jun 1, 2013 | 11:30 PM
Ang Wen Yan's Avatar
Clearly written Poncam Type R
Old Jun 2, 2013 | 02:23 AM
IGGZ's Avatar
I am looking to get some improvement in the top end, without losing spool, and having reasonable idle. I am not chasing top performance. I would like to keep the stock valvetrain. I was also considering HKS 272s. Any advice would be appreciated. Thank you.
Old Jun 2, 2013 | 02:50 AM
EvocentriK's Avatar
They are way more aggressive than HKS 272's (compare duration @ 1mm lift) and if anything you'll gain spool the intake cam is very advanced with LCA @ 105
Old Jun 2, 2013 | 03:32 AM
IGGZ's Avatar
Where can you get this info? I couldn't find it. Also could you safely use Kelfords 272s, FP FP4R, or Cosworth M2s without changing springs ? If you keep the rev limiter stock.
Old Jun 2, 2013 | 05:37 AM
Benja's Avatar
No, they all require valve train upgrade.
Best stock valve train cam going IMO.
Old Jun 2, 2013 | 08:18 AM
EvocentriK's Avatar
Here: http://www.tomei-p.co.jp/cam_spec/4g...2_evo4-8LE.pdf
I'd have to agree, but not far behind are Tomei Poncam 260 and GSC S1 if you want something a little more mild.
Old Jun 2, 2013 | 10:00 AM
TommiM's Avatar
I have my cam card with all that info for my tomei type Rs. Ill dig it up and post the info.
Old Jun 2, 2013 | 03:55 PM
EvocentriK's Avatar
I linked it in the post above yours Tommi.
Old Jun 25, 2013 | 04:20 PM
luckybull's Avatar
i have the 270 pro cam.
it makes great power and drives nicely!
we were able to tune out most of the lope at idle.
they make wicked power and are all around great cams!
