poncam type r 270 cams
Old Jun 25, 2013 | 04:21 PM
luckybull's Avatar
i have the 270 pro cam.
it makes great power and drives nicely!
we were able to tune out most of the lope at idle.
they make wicked power and are all around great cams!
Old Sep 2, 2013 | 11:13 PM
IGGZ's Avatar
So do you need to degree them to make them idle semi normal? Thank you.
Old Sep 4, 2013 | 03:12 AM
sparky's Avatar
I'd like to know if luckybull installed them on a IX, or a non-Mivec Evo?
Old Sep 4, 2013 | 06:18 AM
SmurfZilla's Avatar
I must be old school because I love the muscle car lope.
Old Sep 4, 2013 | 11:29 AM
Nemaris's Avatar
I also have the tomei 270 pro cams, not pon cams. They give a really nice muscle car type idle. Not super aggressive, but aggressive enough to put a smile on your face
The car likes to lope a bit when riding slow in first, but that's it.
Old Sep 4, 2013 | 01:47 PM
jspecteggy's Avatar
+1 Love me a lopey car at idle . My 9 has a little lope to it with just the stock cams and I would love to hear more of it, never understood why people tune out the lope unless they're going for a sleeper type of deal but lets be realistic here we drive EVO's
Old Mar 20, 2014 | 06:46 PM
sparky's Avatar
Originally Posted by EvocentriK
I have run them, I liked them. I found idle was too choppy for me and changed them out, but when driving they are solid, good spool good midrange and topend, gained ~20kw peak from cams alone. I'm not really a cams person they tend to annoy me so take my opinion with a grain of salt.
Did you install them straight up(0/0)?
Old Mar 20, 2014 | 09:34 PM
TommiM's Avatar
I installed mine straight up. I just got tuned on these cams. WIth the last setup I made 278 hp 268 ft lbs at 21 psi. This setup I upgraded to oem stock 9 turbo vs. evo 8 turbo, And Tomei 270 cams 10.7 in 10.2 exh. I dynoed 314 hp/ 320 ft lbs at 23.5 psi. Keep in mind I also put back in the stock catalytic converter compared to a test pipe I had with the previous dyno run, and we turned down the timing a bit. previous setup was like 15s, current timing is around 11s. We were seeing a bit of knock which I think is phantom knock due to my the vibrations from some things I need to address. To play it safe we turned the timing down but still made nice numbers, imo. both of these runs were on 91 pump gas.
On the street, these cams really wake up the car. I love the driveability and response of these cams.
TwStDeVo
Sep 24, 2015 09:02 AM
xi
Feb 22, 2015 07:00 PM
Noize
58
Oct 15, 2012 12:08 PM
Boostfiend
78
Aug 14, 2012 02:54 PM
