Shift Linkage went out?
Old Jun 10, 2013 | 07:35 AM
Topshot's Avatar
Just wanted to confirm with you guys. So on the way to work, go for 3rd gear and the shifter goes 'limp' and the tranny is stuck in 2nd gear. No noise, no drama. The shifter goes back and fourth but will not go side to side or in neutral. Again feels limp. Clutch pedal still offers resistance and feels like it's still working. Fortunately I wasn't too far from home so I just drove it back in 2nd gear. I'm guessing it's the shift linkage? Anything else maybe?
Old Jun 11, 2013 | 10:30 PM
matrho2792's Avatar
Do you have an aftermarket clutch? Sorry to say, but it sounds like the wave clip popped off the throw out bearing.
Old Jun 11, 2013 | 10:50 PM
BEKevo's Avatar
Doesn't sound like the wave clip or retaining lock popper off. Especially if he has pedal pressure.
Old Jun 12, 2013 | 06:45 AM
evo8426's Avatar
Remove the battery and take a look at the paddles that the shifter connects to, there is a pin that holds these paddles to the transmission and it can become dislodged. If this has happened use a socket and an extension to pry the pin back in. I have had it happen 2 times ever, once I had to get towed 45 miles home, the other time I was able to get back home with being extremely cautious trying to stay in 2nd gear like you stated.
There was a TSB for it on the 2003 JDM 6 speed Evos, I'm fairly surprised it doesn't happen more often considering my luck with it.
Old Jun 14, 2013 | 01:29 PM
Topshot's Avatar
Turns out one of the shift linkage cable broke or snapped. $150 part and some work to do.
Old Jun 15, 2013 | 06:49 PM
BEKevo's Avatar
Interesting... Easy fix tho!
Old Sep 2, 2022 | 11:26 AM
Moody's Avatar
Shift linkage cable snapped
Does the shift linkage just screw on or thread on to the rest of the linkage?
Dambay
15
Jul 23, 2018 11:00 AM
Malfury
Aug 25, 2015 03:39 PM
iwantevonow
May 18, 2015 08:51 AM
merchomini
Nov 12, 2012 11:42 PM
bluebyu06
Jul 17, 2011 07:00 PM
