Did DIY Clutch, have a problem now!
Old Oct 7, 2012 | 07:07 AM
merchomini's Avatar
Changed out my clutch, did the whole thing, put it all back together, when i put the shift linkages back on i had a sloppy gear selector that when in gear had loads of play side to side. It also was only getting into revers, 3 and 4th, although it felt as if i was in the spots for 1st and 2nd, and i could go into 5th with the shifter but it would only be in 3rd or 4th. If that makes sense?
Im pretty sure i know what the problems are.
http://www.3si.org/forum/attachments..._installed.jpg
this picture shows where a white cube that has a half moon on the top of it goes.
I no longer have this cube. I think this is what helps direct which gear in the tranny u are going in to.
http://www.3si.org/forum/attachments...ifter_cube.jpg
this picture shows where the cube goes and the assembly. I beleive i bent the upper most arm that one of the shift linkages hooks up to, at some point when the tranny was removed for the clutch.
In conclusion i need a new shift linkage arm to attach to the pictured assembly as well as the white half moon cube......I dont know where to find it? Do i just go to the dealer to get it or is there a way to find it online and order it.
thanks guys
Old Oct 7, 2012 | 07:20 AM
lostsoulsevo's Avatar
make sure the shift linkage bushings are still there and fastened correctly
Old Oct 7, 2012 | 07:22 AM
boosted91t's Avatar
Had a clients car with the same issue, white slider was very badly worn. Could be shift linkage as well if you caught it on something during the install. Check on one of the oem vendors websites or the used parts section.
Old Oct 8, 2012 | 05:06 AM
2theMAX's Avatar
Call Jacks Transmissions. They may be able to help.
Old Oct 8, 2012 | 09:51 AM
merchomini's Avatar
I think this was it, my white slider is not even coming in contact with the metal its supposed to be butting against. Went to mitsubishi and ordered a new slider, and shifter arm because mine may be bent. Hopefully that will solve the problem.
Thanks for the help guys, ill let you know when i put the new parts on.
Is there a better place to order these parts? Oem parts? i looked in a few places but they didnt seem to have everything, i couldnt find what i needed.
Old Nov 12, 2012 | 09:41 PM
9SecSLC's Avatar
How does this white piece re-attach to the shifter arm?
Old Nov 12, 2012 | 11:42 PM
chad99evo's Avatar
remove the linkage it attaches to. little bit of grease. slide it on. replace as complete
RelentlessEVO
Dec 8, 2015 08:15 PM
nefariousdeeds
11
May 17, 2013 12:56 AM
Redspeed
Aug 28, 2011 04:45 PM
joseph143
Jan 25, 2011 01:29 PM
tke_413
25
Jan 7, 2007 08:23 PM
