whats this tapping noise?
Old Jun 10, 2013 | 10:30 AM
SSickLS1's Avatar
not my car or video but i have a friends evo that sounds identical to this tapping and not quite sure what it may be, he does have upgraded lifters in the car. any educated opinions are greatly appreciated
Old Jun 10, 2013 | 10:38 AM
ak47po's Avatar
Could be injectors,mine click like that.
Old Jun 10, 2013 | 10:41 AM
BEKevo's Avatar
^ Those would be some loud injectors...
Could also be a sticky lifter or a stubborn rocker arm smacking something it shouldnt..
Old Jun 10, 2013 | 10:42 AM
Nickygixer-k5's Avatar
Lash adjusters
Old Jun 10, 2013 | 10:48 AM
BEKevo's Avatar
Originally Posted by Nickygixer-k5
Lash adjusters
How do you go about "lashing" hydraulic lifters?
Old Jun 10, 2013 | 11:02 AM
http://www.shop.indigo-gt.co.uk/prod...0e6f73cb53119c
Old Jun 10, 2013 | 11:10 AM
kaganader's Avatar
You misinterpreted what he said.
A lash adjuster is the same thing as a hydraulic lifter,
A hydraulic valve lifter, also known as a hydraulic tappet or a hydraulic lash adjuster.
Sounds to me to be a Lifter.
Old Jun 10, 2013 | 11:15 AM
BEKevo's Avatar
I see. Thats for the clarification guys
Old Jun 10, 2013 | 11:19 AM
I sometimes forget different meanings across the pond
Old Jun 10, 2013 | 01:36 PM
SSickLS1's Avatar
even with having upgraded lifters you guys still think it could still be that?
Old Jun 10, 2013 | 06:53 PM
SSickLS1's Avatar
bump
Old Jun 10, 2013 | 09:33 PM
evoyrrah's Avatar
I had the exact same noise on my 2.4....turned my timing belt was off. I adjusted it to tdc and noise was gone...sounds like piston slap which had me worried
Old Jun 11, 2013 | 05:36 AM
Sil'vr-Boi6's Avatar
I gonna say injectors- injectors sound exactly like that but less pronounced as in this video, get the injectors flow tested. Get a long flat head screw driver, while car is running, gently place the flat head on the injector you should hear a rapid and faint close open sequence of the injectors. There is a how to on this forum. I'm thinking your buddies injectors need cleaning. GL
Old Jun 11, 2013 | 07:35 AM
SSickLS1's Avatar
The injectors are basically new, I can hear the injectors making the normal clicking but this click is different sounds more metallic tapping
Old Jun 11, 2013 | 04:12 PM
BEKevo's Avatar
What aftermarket or upgraded lifters are they? GSC ? Some are required to be "bled", while some do not. If that turns out to be your injectors, those are some loud injectors
