Car Shaking Bad at low RPMs - Is it the Cams? or the Tune?
Old Jun 15, 2013 | 03:11 PM
evo8426's Avatar
Try setting it just like the OEM cams were without changing the degree. The specs are just telling you a little bit about how the cam is designed since it is one of the ways people compare one set to another.
Old Jun 15, 2013 | 03:19 PM
TURBO_S2K's Avatar
then what is the purpose of getting adjustable cam gears?
not criticizing what you are saying. just trying to have some ideas
Old Jun 15, 2013 | 06:35 PM
Hi Im Vinh's Avatar
Had this problem on my IX when I installed S2s as well , a friend of mine tweaked out my mivec some and it went away
Old Jun 16, 2013 | 09:33 AM
Dynotech Tuning's Avatar
Datalog the injector pulsewidth and MAP sensor so we can see what's going on there.
-Jamie
Old Jun 16, 2013 | 09:56 AM
TURBO_S2K's Avatar
-Jamie
will take a log and post it as soon as I can
Old Jun 16, 2013 | 10:22 AM
prowakeskater's Avatar
i think 11.8* of timing at low load and 1500 RPM is your problem
Old Jun 16, 2013 | 10:33 AM
evo8426's Avatar
I highly doubt that, that low of timing would not cause the car to jerk back and forth like it is in the video.
Old Jul 3, 2013 | 04:00 PM
TURBO_S2K's Avatar
latest video and log file
I was using Windows on my Mac so I couldn't do a print screen. That's why I took a picture, hope it is OK
Old Jul 4, 2013 | 10:37 AM
You really need to post a datalog up. Make sure to log the RPM, injector pulse width, TPS, load, timing, IAT, and AFR.
I really can't make out anything too well in the images but I can see the TPS is fluctuating a lot. Is that from your foot bouncing on the pedal? If not, you may have a bad TPS sensor or bad connection.
This may help you take better screenshots with the items listed above:
http://answers.yahoo.com/question/in...9155036AAVkPWe
-Jamie
Old Jul 5, 2013 | 09:24 AM
TURBO_S2K's Avatar
-Jamie
The thing is I am using Windows on my Mac and I cannot take screenshot while using windows. I can take screenshots as explained in the link but only when I am using OS X
I will try though...
I am actually keeping my foot steady on the pedal
I believe when the map is fluctuating, it also messes up the throttle
I am trying to send you the log file but somehow I cannot find it under Logs folder
when I try to open the log file from AEMLog, I see the file.
When I try to open it from Windows Explorer, I can't locate the file as if it is hidden
I can send you log file if I can find it.
I don't have AEM WB hooked up to the ECU though so I can't log the AFR
Old Apr 18, 2014 | 03:44 PM
EvoTurboTurk's Avatar
Has anyone seems to find the solution for this problem?
Old Dec 10, 2016 | 09:53 PM
Miguel Junes's Avatar
Help please
My car shakes while taking off in normal rpms in first gear.but if I take off in higher rpms 2.5 and above it doesn't shake. Once I let go of the clutch it stops
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
coreymelton
Aug 15, 2017 10:01 AM
Alchem1st
Jul 28, 2017 01:15 PM
xxorathaa
May 7, 2017 06:36 AM
JosRacing4G94T
May 3, 2017 10:58 AM
