What does backpressure do to a motor?
Old Jun 20, 2013 | 03:15 PM
  #61
Grimgrak's Avatar
For the cost of what you've spent welding two bungs to measure your backpressure would be peanuts.
Old Jun 20, 2013 | 03:19 PM
  #62
Grimgrak's Avatar
Mustang dyno #'s so i'm on a full built 2L ported head/ams t3 turbo kit etc. It is very frustrating. If I got these #'s stock i'd be doing back flips.
Originally Posted by Joshs EVO
I wouldn't lose your mind over it like I am. I've literally replaced everything that we thought of. You only running a stock turbo probably haven't or are at the ends of the turbo where as I am not even in the thick of the powerband for this turbo yet its not making power. Slight difference between my car and yours.
Old Jun 20, 2013 | 03:44 PM
  #63
Joshs EVO's Avatar
Sorry assumed for some reason you were stock.
Old Jun 22, 2013 | 03:14 PM
  #64
Joshs EVO's Avatar
Car made it back to my house today after being at DB's for 6 months. Upon initial startup after getting it off the transport truck the ACD lights were all on and the idle was around 2500.
Just as the first step I made a physical observation of the muffler and it's not a Varex as there isn't a flapper valve in there. and it seems that there isn't anything in the muffler blocking anything.
Old Jun 22, 2013 | 03:51 PM
  #65
Joshs EVO's Avatar
I take that back car won't idle normally now. Car has been running at 2000+ rpms for 10 mins now.
Old Jun 22, 2013 | 05:57 PM
  #66
Dynotech Tuning's Avatar
Check all vacuum lines going to the intake manifold and ensure that the throttle plate is 100% closed.
Here is a link to diagnose the 3 ACD lights.
https://www.evolutionm.net/forums/9356352-post10.html
-Jamie
Old Jun 23, 2013 | 04:44 PM
  #67
Joshs EVO's Avatar
-Jamie
Jamie,
Cool thanks. I will see about doing this. As of right now I will not enjoy the car but let it sit what its done mostly for its ownership of 6+ yrs.
  #68
Joshs EVO's Avatar
I've added Dyno sheets on the first post on page 1. Tell me what you think..
Old Jun 24, 2013 | 07:35 AM
  #69
ba109296's Avatar
What head and valve springs are in your head now?
Old Jun 24, 2013 | 07:47 AM
  #70
ba109296's Avatar
Car*
Old Jun 24, 2013 | 08:58 AM
  #71
Joshs EVO's Avatar
Whatever the Buschur Head Stage III comes with. I think they are some brand he sticks in them.
- Custom BR dual stainless steel valve springs
- BR titanium retainers
- New Valve Seals
- BR stainless .5mm over intake valves
- BR stainless .5mm over exhaust valves
- Stainless Oring around each combustion chamber
- Complete port & polish job
- Stainless Steel O-Ring
Old Jun 24, 2013 | 09:04 AM
  #72
project_skyline's Avatar
Supertech duels, not sure which combo but probably enough for bigger cams.
Old Jun 24, 2013 | 09:30 AM
  #73
The best thing is to physically measure the back pressure between the turbo and the head. My guess is improper cam degree and overlap or an exhaust restriction somehow.
-Jamie
Old Jun 24, 2013 | 09:53 AM
  #74
Joshs EVO's Avatar
-Jamie
How would one do this?
Old Jun 24, 2013 | 10:22 AM
  #75
way2qik's Avatar
Josh, I already explained how to do this.
