422whp/365tq Stock block PTE6262
Old Jul 18, 2013 | 03:19 PM
Harumsevo's Avatar
Well long story short. Bought my evo from a member on the forums here. I was told the car was in perfect running condition and compression was perfect. I flew out to purchase this car all the way to Boston ( I live in Iowa ) I flew down and drove the car back 1456 miles without issues!! Next day car wouldnt start up. After the car sat for a few weeks I was upset about it and had to get it running again. I contacted a few shops and out of all them the closest shop was Boostin Performance. I towed my car out there and had them work on it.
After taking the head off they found out real bad damage to the block.
11k later my car is finnaly running.
Tuned by Devin at Boostin Performance.
Brand new OEM 2.0 Block
DTT PTE 6262 Kit w Tial 44 MVR Wastegate
DTT 3" SS O2 housing
DTT 4" Intercooler (Garrett)
DTT 2.5" Aluminum Intercooler Pipe Kit
HKS Exhaust cam
HKS gear
3" Stainless Turbo Back exhaust
walbaro 255 fuel pump
Invidia Header
Zeitronix WBO2 w/ 2" Display
FIC 1250cc injectors
Grimspeed Boost Control Solinoid
ARP Headstuds
Tial Q BOV
Spooling Up Coil on plug Ignition
3" Injen Intake
Stoptech SS Brake lines
Exedy Twin HD w/ new TOB and clutch pill removed
STM Clutch Stop
Sorry for the bad dyno graph pic. Ill try to get a better one
Heres the dyno video:
Old Jul 18, 2013 | 03:35 PM
triple L's Avatar
this has to be on pump.... and sorry to hear bout the bad block... very skeptical when buying online but anyways good numbers hope to see some e85 numbers
Old Jul 18, 2013 | 03:37 PM
ctfpevoVIII's Avatar
Sorry to hear about your misfortune . Those are some solid numbers on a mustang dyno , the car must rip. This tune was on 93 oct? So what type of damage did the engine have?
Old Jul 18, 2013 | 03:40 PM
Harumsevo's Avatar
She gets up and goes
and yess car was tuned on 93 pump at only 25psi
When the head was taken off all pistons had damage. Piston #4 had chunks missing. All of the rings were complete ****. One side of the block was surfaced down so bad that the head gasket could not seal up.
Old Jul 18, 2013 | 03:49 PM
Man that sucks. I remember when you first got your car and posted it , I also recall you had a problem with the water turning to ice in your spark plug holes. Well its good to hear your car is running like a beast now. I see that you have a new oem block, since you had it all opened did you go with some nice forged pistons and rods?
Old Jul 18, 2013 | 03:55 PM
Harumsevo's Avatar
Originally Posted by ctfpevoVIII
Man that sucks. I remember when you first got your car and posted it , I also recall you had a problem with the water turning to ice in your spark plug holes. Well its good to hear your is car is running like a top now. I see that you have a new oem block, since you had it all opened did you go with some nice forged pistons and rods?
It was doing the same thing before the water incident and I could never figure it out. Came out to be the motor had no compression what so ever. Unfortunently I did not. Went with a new OEM block. Replaced all seals/gaskets through out the whole motor. Re did the head. Brand new water pump, oil pump. And so on. All timing components replaced. I daily drive the car so I didn't want to go with a full bottom end build. Majbe down the road when I get used to this power
I will make a new thread about the build sometime tomorrow.
Heads up to anyone double check the car your buying and do not jump into something sketchy.
Old Jul 18, 2013 | 04:00 PM
MyronGainz's Avatar
This. It seems to be pretty common with these kinds of cars... people get sick of the maintenance, run it into the ground and then sell it to someone else so that they can deal with it. Sucks that you had to go through that, but good to see that you made the best of it and you can put down some awesome numbers now
Old Jul 18, 2013 | 04:10 PM
Harumsevo's Avatar
Yeah its kinda sad. But I learned my lesson. I thought I got a steal of a deal being a low mileage MR with some goodies on it.
Old Jul 19, 2013 | 10:59 AM
evo8426's Avatar
Do you have any pics of the DTT upper IC pipe? It looks like one that I would like to pick up.
Old Aug 20, 2014 | 12:21 PM
bouncer07's Avatar
Was probably driving on a bad tune all the way back home.
Old Aug 20, 2014 | 12:39 PM
20EvoX12's Avatar
^^ That and I bet the previous owner took some stuff off before selling and never adjusted the tune for it. Typical problem.
Old Aug 20, 2014 | 08:44 PM
slowsrt4:('s Avatar
sucks about the car, weird that it drove that many miles then finally crapped out.
Old Aug 20, 2014 | 09:27 PM
McDougal's Avatar
I'm on nearly the exact same setup but without cams. I made 422 but it was on a dynojet and was told I'd be at 450 with s2's. You'd probably be at 450 on a dynojet right?
How do you like the 6262? I like mine quite a bit. A little laggy but not too bad.
Old Aug 21, 2014 | 06:54 AM
Craig King's Avatar
OP, how did you handle the engine issue with the previous owner? I realize car sales are as-is, but did you inform the previous owner of the issues? What was the outcome?
Old Aug 21, 2014 | 03:22 PM
I don't know if the op ever contacted the previous owner but I believe the op has sold this vehicle at the beginning of the year. He hasn't posted in quite some time.
