running a turbo xs lower intercooler pipe similar to the ets v2 pipe. and im going to install a hafe t3 cast turbo manifold and HTA 3586R turbo. what do i have to modify in order to get this to work?
i would like to find out before i swap everything on so it all goes smoothly. this is my daily driver and i would like it to be down for a minimal amount of time.
any suggestions would be greatly appreciated. thank you
I use an ETS Lower IC Pipe but had to use a long coupler that had a bend to get it to work.
any way i could see a pic to see exactly what kind of bend and coupler id need? thanks for your reply!
The MAP LICP looks like it would fit fine but test fitting with the kit on, it should be as simple as a single coupler.
Quote:
dude i owe you one. if your ever selling anything on here send me a pm and ill do what i can to help you out. thanks againOriginally Posted by abazaba410
yeah not a problem. I will snap you a pic shortly and try to get in posted today
pm me your ph# and i can send you those pics. They arent the best pics but without a lift it was the best I was able to pull off.
I will upload them tomorrow if you remind me. I just got home late the last 2 days.
