Aeromotive Double Pumper w/ pump #1 dead as of now
Well i will just start this thread with what my fuel system consists of...
I have all braided-8 lines from front to rear eliminating all factory lines. I am running e98 and have a full tank of fuel with a Full Blown Double Pumper hanger with 2 Aeromotive 340's feeding the pig. The car has a very conservative 35 psi tune on an AEM V1 that Jordan @ MAP kindly did for me. The second pump is triggered by a Hobbs switch that we are very certain kicks on under boost. Right before we were going for a cruise we briefly did a good solid pull and then just cruised which no more than a minute later the main pump just stopped running. There is power at the pump and before i go ***** deep into removing the mess i want to assure myself that i am making the right decision by removing it.
Could it be the ignition switch that triggers the pump to turn on?
No fuses are blown.
Could a relay fail and cause it to not turn the pumps on?
Has anyone ever had an issue with this?
Could it be a hanger failure or from too much vibration the wires simply came off?
Or am I just that one small minded idiot running e98 through a factory fuel tank?
Could it be the AEM?
Any advice or suggestions are certainly welcomed!
Thanks,
Justin Reaves
jrblackSE
No fuses are blown.
Thanks,
Justin Reaves
jrblackSE
jrblackSE
Sep 13, 2014 07:44 PM
jrblackSE
26
Aug 30, 2012 11:02 PM
mlomker
12
May 6, 2011 07:30 AM
churchja
11
Jun 18, 2010 11:45 PM
