engine bearing need help
Old Aug 1, 2013 | 05:01 AM
race_tech's Avatar
hi guys
i want to build my evo, since i read in this forum talking about using 4G64 crank, can stroke up to 2.3 ltr
i want to use 64 crank which engine bearing should i use the original 4g63 engine bearing / use the 4g64 engine bearing, or do u guy's have any other option
because when i saw both of them is different and also the 63 engine bearing is smaller than 64 ( 64 is wider )
and the 64 still using thrush bearing and 63 already one piece with the engine bearing
Old Aug 1, 2013 | 06:53 PM
batty200's Avatar
You are probably looking at an older 64 because the compatible 64 block uses the same rod main and thrust bearings as a 4G63.
senate6268
128
Sep 3, 2015 10:44 PM
tobosoerick
Jul 2, 2015 10:22 AM
Howulikemyevo
Jun 8, 2013 10:10 AM
craigybaby37
13
Sep 1, 2011 03:02 AM
bryonboals
Aug 19, 2011 02:57 AM
