4g64 evo bearing clearances
Old Aug 19, 2011 | 09:29 PM
craigybaby37's Avatar
Hi all im just after a little bit of input as to whats a good clearance to run in my 4g64 main and rod bearings??
Bearing i am using are ACL bearings with 4g64 cranks and oliver extreme rods??
Thanks
Craig
Old Aug 19, 2011 | 09:38 PM
n2oiroc's Avatar
Thanks
Craig
what kind of rpm's are you planning on running?
Old Aug 20, 2011 | 12:44 AM
No more than 8500rpm I would say
Old Aug 20, 2011 | 01:35 AM
RSMike's Avatar
oil choice is more important imo.
I used 0.06mm (2.4thou ish) on my mains with 15W-50 Motul 300V
Old Aug 20, 2011 | 06:12 AM
Thanks for the reply, 2.4 though sounds like a good enough oil clearance for a high reving engine as i was recommended to run my clearance than the standard spec
I have got all ACL race bearings that are the HX series so have a tiny bit extra clearance over standard bearings.
Old Aug 20, 2011 | 07:18 AM
n2oiroc's Avatar
.002" should be plenty wide for the rods.
Old Aug 20, 2011 | 10:01 AM
420a-t's Avatar
It depends on what you want to do with the motor. I've ran the x series acl bearings before and they worked ok, my oil pressure was lower than I would have expected so I had to step up to a 50 weight oil to keep them happy in my 2.3 build FYI.
Old Aug 20, 2011 | 10:18 AM
I have seen a few people now using .002" for there clearance....but then earlier i was looking through another UK build of a 2.4 4g64 and he used .0025"
Car is going to be my daily drive but hopefully ill do some track time in it should all goto plan.
The crank is at the machine shop now being balanced and all the journals and oilways micro polished so when its back i can plastigauge everything to see what clearances i have and go from there......if they are to big i can just change the bearings to the non HX then check the clearances again.
The 4g64 crank is brand new and had II II II II stamped on it which i presume the size of the bearings that would of been fitted by
Old Aug 20, 2011 | 10:39 AM
n2oiroc's Avatar
i dont know why people go so big, to me even .002" seems pretty loose.
Old Aug 20, 2011 | 11:47 AM
The mitsi spec for the main bearings is between 0.03mm and 0.05mm and when you convert 0.05mm to thou it's just over .002"
Old Aug 29, 2011 | 12:05 PM
Well the engine is now back together and i ended up with 2.5 though on the mains and 2 thou on the rod bearings
The company i use for all my machining work have said i will be fine with them clearances
Old Aug 29, 2011 | 12:18 PM
RSMike's Avatar
what viscosity oil are you going to be running though?
Old Aug 29, 2011 | 01:26 PM
Paul Walkin's Avatar
Should work fine, just run a quality 20w50 or similar
Old Sep 1, 2011 | 03:02 AM
Well either a 10w-50 or 15w-50
Will give them a try first an see what pressures I'm getting then if need be toto a thicker oil
2006GSR
10
Jun 17, 2019 11:07 AM
babaz7
34
Oct 13, 2017 04:57 PM
06EvoIXmr07
24
Apr 7, 2016 10:37 AM
canitbethislong
Nov 25, 2012 09:42 PM
jamie_v1
Mar 27, 2011 07:54 PM
