Trouble re-installing transmission HELP!!!
Old Aug 3, 2013 | 12:59 PM
gianacakos's Avatar
This is killing me. Things were going super smooth, but im just not confident ive gotten the tranny close enough to the block. It got to this point easy and it "feels" mounted. Ill attch some photos.
Old Aug 3, 2013 | 03:13 PM
TommiM's Avatar
It may not go in more because your fighting the angle, the slight tilt of the transmission. I just put mine in recently so this is fresh in my head.
You need to lift the rear half of the trans-- where the tc is at. What I did was got some regular ratcheting tie straps, wrap around the back section of the trans only. Be careful to not get close to sensors, but try to keep it strapped only in the rear motor mount area. put the ratcheting part over the strutbar and use that as your brace. start ratcheting slowly until you get that perfect angle and it should slide right in.
Ill try and post some pics, but this worked flawlessly for me, and it literally went in right away without much effort. G/L.
Old Aug 3, 2013 | 04:52 PM
gianacakos's Avatar
Got it in...thanks
Flumpy J
02-03 Lancer Show / Shine
34
Mar 28, 2017 04:08 PM
gianacakos
Apr 7, 2014 04:13 PM
dtrackstar
Sep 23, 2013 10:37 AM
Adio
Aug 4, 2013 10:07 AM
Jp7
11
Dec 24, 2011 04:31 PM
