Evo 4 to 8 swap, oil cooler issues
Old Aug 8, 2013 | 12:34 PM
Dvolution's Avatar
Just swapped a VIII into my IV. The oil cooler banjo bolts on the 4 are smaller than the ports on the 8's filter bracket. I would like to swap the filter brackets to solve this problem. Since the engine is already in the vehicle it going to be a pain to get out and I would like to make sure it is possible. Will the IV oil filter bracket bolt on to the VIII engine with no problems?
Old Aug 8, 2013 | 03:22 PM
Yogi_B's Avatar
The oil filter housing?
Yeah they'll swap over fine.
Why don't you just go for an oil cooler off an evo6+ or an aftermarket one? The evo4 cooler is the smallest of the lot.
Old Aug 8, 2013 | 05:29 PM
wang4u's Avatar
Id upgrade. Yogi is right, the 4s cooler is dinky. You could save a few bucks and buy a STM kit for a 8/9. Or if you want big upgrade, building it yourself. Personally, I wouldnt buy a stock off a 6 or a used one. Coolers should be replaced if the engine is replaced (or engine blows). Therefore, I wouldnt use your 4 cooler either.
www.improvedracing.com if you want to build your own Setrab kit. Put mine together for a E5 under $400 shipped, using very badass AN connectors.
Old Aug 8, 2013 | 06:16 PM
SaulHudson's Avatar
I speak from experience, it is very difficult to fit the 6+ cooler on the 4 chassis. The oil cooler brackets will not just swap over and fit fine, either. I used the 6 cooler and lines, used a combination of brackets highly modified and cut the fitment stems off the lines on both the cooler and filter housing side.
If I were to do it again I would defiantly swap to a 4 oil filter housing and use a 4 cooler or delete it all together, as so many people don't run one at all and have no issues.
Old Aug 8, 2013 | 06:41 PM
Dvolution's Avatar
Thankyou for your information and suggestions, everyone. I will swap the filter housing and retain the old oil cooler.
Old Aug 9, 2013 | 05:38 AM
94AWDcoupe's Avatar
I have done this a couple of times by carefully boring the banjo fitting so the larger bolts can be used. so you can use evo 8/9 cooler with the smaller 4 lines. or in your case the smaller lines and cooler can bolt to evo 8 bracket.
STM Tuned
May 5, 2019 12:51 PM
mick9ornothing
Apr 4, 2017 11:21 PM
4g63girl
Dec 26, 2016 10:56 AM
STM Tuned
Dec 4, 2015 08:19 AM
AutoMotoSports
Jul 17, 2009 09:32 PM
