HKS Twin Power DLI-II CDI Ignition System
Hey all,
I see there are quite a few people running this CDI system on here but nobody has really posted any results save for a few threads (one results, other Sparktech Non-CDI vs. HKS DLI-II). My question for all of you folks running this system, why the hell doesn't this have a 12V direct to the battery like every other CDI box I've ever seen?
I bought it used, with no modification to the harness, just a plug-n-play setup:
It didn't come with instructions or a wiring diagram, but then again it really shouldn't since it's PNP. However, that said, I've never seen a CDI box that didn't have a direct 12V to the battery. How does this sorcery work? Or does it even work the same way as the M&W boxes?
all you have to do is ground the black wire i made 831 whp with one on e85 so i say they are pretty good my gap was pretty small on the plug but still worked well for the money at the time. now i have a spoolin up cop and the hks box powering it so i should have enough spark for anything now.
I use to run one of these and it worked great while it did, but mine crapped out and the car started misfiring real bad. I now run a spark tech cop non cdi . I have heard that the vibration in the engine bay kills these HKS units so choose a good spot to mount it. I would like to hear if others have any experiences of failures with these.
Thanks for the input guys, all this is very helpful. I knew how to hook it up I just don't really understand how this unit can claim to be a CDI type when it isn't pulling any voltage directly from the battery like every other CDI box I've ever seen. That part was strange to me.
my dli just die.....
, i got my plug and play harness so i decided to get the universal one but dont know how to get it plug with my old harness.. any ideas? or diagram so i could figure it out to make the pin out... please help!!
David Buschur
34
Mar 7, 2012 01:20 PM
