next turbo up from gtx3582
hi guys just in process of rebuilding engine after melting the pistons, my aim is 500kw on e85 with 2.0litre on a fully built motor capable of 10,000rpm and 35psi+ boost. im running low comp 8.3.1 in the hope of running more boost on a particular octane fuel. anyway im thinking the gtx turbo will not be enough to reach the power level im hoping for, and would like some advice on a recommended turbo to reach this power level. thanks
if I went bigger such as the gt4088 im guessing id be picking up midrange torque, running less boost but more lag, depending on A/R , would this be right? for 500kw
im swaying more towards pte 6262 now
BTW, there are plenty for sale right here on this very board.
As you know, Precision is virtually unknown in NZ where everyone seems to be fixated on GT Garretts but you just don't have the good twin scroll housings available till the 4088.
I'd go borgwarner personally but you could try importing a precision.
If money is no object:
FP HTA GT3786R Ball Bearing Turbocharger
http://store.forcedperformance.net/m..._Code=Turbo-FP
If you on a Budget Garrett GT3788R Ball Bearing Turbocharger in a T4 1.15 twin scroll setup
If you dont need the reliability of a Garrett Ball Bearing Turbocharger then:
Precision 6266 or 6466
regards
Sal
regards
Sal
MadBoostedEvo
46
Feb 22, 2022 02:24 PM
riceball777
21
Dec 12, 2015 07:18 AM
