get me to 450
Old Sep 11, 2013 | 07:41 AM
jhoganusaf's Avatar
get me to 450
so ive had my car for 2 years now, and i set a goal of reaching 450whp. just wondering if anyone had any ideas on how to get me there. i only have access to 91 octane fuel. and plan on ordering AEM's water/meth kit. current mods are in the signature. thanks for any replies.
Old Sep 11, 2013 | 09:04 AM
evolve_VIII's Avatar
What are your numbers now? How much boost are you running? I know your mods are listed but do you have a stock bottom end? Is this your DD? 450whp is getting close to pushing the stock bottom and keeping reliability.
I have 2 meth kits for sale if interested. https://www.evolutionm.net/forums/sa...-oem-more.html
Old Sep 11, 2013 | 09:10 AM
jhoganusaf's Avatar
it is a DD on stock bottom end. i have a set of pistons and rods in my storage unit that im saving for a rebuild. its never been on a dyno, but i want to think its in the ball park of 310whp at 20psi.
Old Sep 11, 2013 | 11:17 AM
Ok. You can turn up the boost with the meth inject. Probably go around 24-28psi or so. Maybe more dependig on how it responds and whos doing the tune.
I would add a down pipe and cat delete along with the meth kit and that should get you into the 400+whp range.
Heres a link to the turbo spec info I found. https://www.evolutionm.net/forums/ev...fications.html
Old Sep 11, 2013 | 11:49 AM
e_kobz's Avatar
To hit 450whp on 91 with water/meth you're gonna need a few more things. For starters you're gonna need a much bigger turbo, something along the lines of a MAP EF3 or a FP Red. You might even get away with a FP Green. You're also gonna need a bigger intercooler, at least 3.5 inches thick. Finally crank up the boost A LOT. Like between 24 and 28 psi depending on the size of the turbo. Most importantly take it to a tuner who is familiar with tuning water/meth injection.
Old Sep 12, 2013 | 08:05 AM
jhoganusaf's Avatar
ive got several parts in a storage unit. im just waiting to get everything for a rebuild. like i said earlier, i have pistons and rods, then i also have a shep stage 3 tranny, buschur t3 manifold, ID1000cc injectors, and a buschur intercooler.
Old Sep 12, 2013 | 08:16 AM
jhoganusaf's Avatar
yea i already have a full turbo back exhaust. perrin downpipe and buschur catback. that turbo spec sheet would have been helpful a while back. definitely wouldnt have bought a 20g. lol
Old Sep 12, 2013 | 08:17 AM
Sharkbite2000's Avatar
bigger turbo, injectors, fuel pump BAM!! 500AWHP with the right turbo upgrade.
Old Sep 12, 2013 | 09:57 AM
jhoganusaf's Avatar
also thinking about getting GSC s1s or S2s.
Old Sep 12, 2013 | 11:00 AM
e_kobz's Avatar
Go with the S2's. the S1 is beneficial if you're running the stock turbo. anything 450whp and over go with the S2
Old Sep 13, 2013 | 01:50 AM
jhoganusaf's Avatar
awesome. also anybody know if the injen intercooler pipes will fit with a buschur intercooler? i dont really wanna buy parts if i dont really need them.
Old Sep 13, 2013 | 03:08 AM
scopy's Avatar
id get the injen upper ic pipe but an ETS lower ic pipe, its just better flow, and thats the one that really matters, and id also do a 272 cams and an external o2 dump from MAP, most people see up to a 20 some odd hp gain just from the dump and up to 12 from the licp, nd then a 20g, walbro 255 and some 1000+cc injectors, along with the blood of a pregnant unicorn and a good tune, you should be alright
Old Sep 13, 2013 | 03:24 AM
jhoganusaf's Avatar
my current mods are in the signature.... already have 272/272 cams, walbro 255 and a 20g. and with my PTE 880cc injectors im only at 57% duty cycle. at 20psi. so the injectors i have are big enough. i have a set of ID1000s waiting to be put in. along with a buschur intercooler. i also already have Injen upper and lower intercooler pipes installed and was asking if these would fit the buschur intercooler. cuz if they do, i wont need to buy more pipes. still planning to get GSC springs and retainers and a set of GSC S2s, and AEM Water/meth kit.
Old Sep 13, 2013 | 03:27 AM
omnigear's Avatar
You forgot to post how much dead presidents are at your disposal
Old Sep 13, 2013 | 03:56 AM
jhoganusaf's Avatar
You forgot how to keep posts in this thread relevant to the topic of discussion.
