BOV question
Old Sep 14, 2013 | 10:03 PM
oscarquinones's Avatar
BOV question
how you doing guys I have a evo 9 currently my modifications are ets intake, ets intercooler, ets stock route intercooler piping, walbro 255, 3 port grimmespeed, precision 1200 cc, turbo timer, megan 02 housing, hks catchback and piping. I have a stock 9 turbo and the stock bov. I want to change the BOV but I don't know the best for my evo. I heard the aftermarket bov gives the evo problem on boost and tune. I want to know recommendations and also I have to change my wastegate if I change the BOV this is base on my stock route intercooler piping. thanks for the help.
Old Sep 14, 2013 | 10:09 PM
bdonIX's Avatar
how much will you be boosting? stock 9 is a solid bov designed to minimize flutter at partial throttle, which is great for DDing. A crushed 9 bov is good for ~28psi +/-
I rock an adjustable Forge recirc. Some people complain about it, but I have had zero issues with it. Just make sure its setup correctly and included in your tune.
Old Sep 14, 2013 | 10:22 PM
with all of this I did in a dyno on 91 362whp and e85 401 at 25 psi. I just did my tune two days ago.
Old Sep 15, 2013 | 12:02 AM
egis's Avatar
^^ not bad numbers on dj.so why u want to change the bov?
Old Sep 15, 2013 | 06:27 AM
if see I can improve my numbers. I am waiting for this week for my GSC cams 2 with the springs and retainers. So I was looking that can help a little more. thanks
Old Sep 15, 2013 | 07:22 AM
st0mp860's Avatar
How much boost is the stock BOV good up to anyways?.. before it starts to see problems?
Old Sep 15, 2013 | 08:36 AM
APEXR's Avatar
BOV shouldn't change how much power you make, unless it's leaking/not holding boost.
Old Sep 15, 2013 | 10:00 AM
as far I my knowledge it holds 25 psi. people if you crush the bov you make a little more 28psi
Old Sep 16, 2013 | 05:57 PM
jason42003's Avatar
If you do end up buying an aftermarket bov just get a tial with the proper spring. They are little spendy but by far the most reliable. The only issue this should cause with you tune is if you get a vent to atmosphere like the tial q, and don't have speed density. If you are still running the stock maf and a recirc setup you can use the tial qr. Then if you decide to go to speed density and want to use a vent to atmosphere bov you just swap the bottom half for a tial q bottom half and your golden. I've use a forge bov (non-adjustable) and it just could not handle even the stock boost level. it would open up at wot and cause my car to buck violently and loose power. Switched to an aps adjustable bov and the bucking went away but I still have issues with it opening at partial throttle (I may just not have it adjusted right. But because of that I am looking to just swap to a tial and stop fighting with the bov. And as for the wastegate the only reason you should need to replace that is if you are looking to boost to a higher psi the wga only controls when your wastegate opens, which controls the amount of pressure your turbo creates.
Old Sep 17, 2013 | 05:15 AM
st0mp860's Avatar
Interesting. Thanks all for the helpful information.
aquaplane
Dec 30, 2014 02:58 PM
Evolution99
Jul 15, 2012 05:15 PM
Mrauto50
Feb 3, 2012 05:36 PM
dinok
Mar 15, 2010 05:34 PM
PsychDr. HN$
Aug 21, 2008 04:51 PM
