Piston Dome Dish and Compression Ratio
Old Oct 23, 2013 | 07:22 PM
JGNERAEVO9's Avatar
Originally Posted by 94AWDcoupe
I calculate with zero deck height compression will be 9.97 with 1.0mm head gasket. with factory .75mm gasket compression would be 10.20. shaving head .010in. would give 10.42.
the above calcs are with your 43.8cc chamber. dont know where you got that number? but factory size is 43cc. using 43cc the numbers go to 10.09, 10.31, and 10.55.
I dont add 1.5/2.0cc for area around top of ring land. that part of piston expands with heat. nearly touches cylinder wall under running conditions.
Stock Evo 8 9 gasket is 1.18mm. According to Weisco it is 43cc this says http://rbid.ru/cr/ 43.8 Evo 4-9.
Old Oct 23, 2013 | 07:44 PM
JGNERAEVO9's Avatar
Anyone need a set of dome coated Weisco HD2s 87mm bore 28.875 mm comp height and dome cc of -12.50cc? lol
Old Oct 23, 2013 | 08:29 PM
Evoloved's Avatar
The OEM HG is not the same for an 8/9 8 being thinner Irc. I have never found a conclusion as to what the 9 measures but they are not the same gasket. So you must take that into account. That calculator is slightly off
Old Oct 24, 2013 | 12:41 AM
94AWDcoupe's Avatar
8 gasket is .026 = .75mm
9 gasket is .040= 1.0mm
Old Oct 24, 2013 | 12:17 PM
JGNERAEVO9's Avatar
Spoke to David at head games he said he took 5thou off the head when he decked. So I need to know what dome cc I need to get 11:5:1 using a gasket of 1.2mm as it will be after market.
Old Oct 24, 2013 | 12:34 PM
JGNERAEVO9's Avatar
I'm calculating 0cc any second that motion or can confirm calculation?
Old Oct 24, 2013 | 06:40 PM
03whitegsr's Avatar
The difference in power between the compression ratios you are talking about is likely to be nil.
No sense in cutting a block, head, or piston if it doesn't NEED it.
When you blow it up, you'll be glad you have that material next time around so you can fix the damage without buying a new block or head.
Old Oct 24, 2013 | 06:55 PM
JGNERAEVO9's Avatar
Not looking to make more power per say looking to make the same power on less boost. Looking for a happy medium on a 76mm.
GravityKnight
21
Mar 2, 2019 01:30 AM
Migsubishi
14
Jan 4, 2017 06:41 PM
villero1834
Lancer Aftermarket Forced Induction Tech
15
Jun 22, 2011 06:32 AM
Mad_SB
10
May 13, 2011 11:46 AM
Nilus
Apr 15, 2010 05:06 PM
