Boost Control.
Old Oct 27, 2013 | 01:58 AM
bumpnz's Avatar
Boost Control.
What is the best way to control boost using a controller.
I did some searching on here and never found anything conclusive but seemed a few people ran a Hallman MBC but im not a fan of manual boost controllers.
So what are the best options for an electronic boost controller? Perfer to be able to adjust from within the cabin and knowing what im running.
Thanks.
Old Oct 27, 2013 | 02:15 AM
ILoveAWD's Avatar
I would suggest the AEM tru Boost controller and gauge... i will be running the grimmspeed 3 port. there is no need to be worried about controlling the boost. if your tuner setup the car then you go and change things, thats normally how it goes KAKA-BOOM
Old Oct 27, 2013 | 06:20 PM
bumpnz's Avatar
Looks like a good option.
I just want to be able to control the boost levels from inside the cabin, can make racing a lot easier at times.
Thanks
Old Oct 28, 2013 | 07:18 PM
sparky's Avatar
Give an example of why in cabin boost adjustability makes racing easier. You are probably correct. I would just like to learn your specific reasoning. What sort of racing scenarios, etc.....
Old Oct 28, 2013 | 11:16 PM
llDemonll's Avatar
Thanks
bad idea.
Get a boost controller, get a tune, and don't touch the boost controller after that.
adjusting it is just asking for a $3k+ repair bill for your motor when you inevitably blow something up
Old Oct 29, 2013 | 06:00 PM
jason42003's Avatar
A safe way to accomplish wut you are looking for would be to get a dual map setup coupled with the grimmspeed bc that way you can run 2 boost levels and be tuned to safely handle both.
LOVEMYX
Jun 13, 2017 06:06 PM
backyardevo8
Jun 15, 2016 03:44 PM
sith_killer_99
Dec 29, 2009 06:01 PM
althemean
AEM EMS
22
Apr 28, 2009 02:24 PM
bigyellowevo
AEM EMS
10
Aug 12, 2005 09:51 AM
