evo 8 wont go into 4th gear????
Old Oct 27, 2013 | 10:45 PM
Evo_8_REDYG0's Avatar
was working fine this morning, took it out again at night couple did a slight 3-4 pull and it wont go into 4th?? ive tried with the car off and it still wont go in all other gears work fine. what could be wrong?
Old Oct 28, 2013 | 01:10 PM
adriano_917's Avatar
The famous 4th gear syncro, happened to me
Old Oct 28, 2013 | 01:13 PM
itsmrrizz2you's Avatar
Mine did the same thing time for new syncro
Old Nov 4, 2013 | 11:40 AM
pinoyevo23's Avatar
The infamous 4th gear synchro happened to me and all my boys. Replace it and you're all good
Old Nov 4, 2013 | 01:27 PM
hiboost2.0's Avatar
Yep, happened to me too. Mine went because I was having a clutch dragging issue that I was unaware of :/
Check your shifter cables before you drop the trans and make sure they're not binding on anything.
Old Nov 4, 2013 | 02:22 PM
OhioWhiteEvo8's Avatar
my trans was acting up going into second and knew it need new sycros but it ended up ruining the gears too so i had to do the basic rebuild along with 2nd,3rd,4th and reverse gears..sucked take care of it before it cost you even more
evo2pwr
Apr 9, 2017 05:15 AM
vboy425
10
Oct 30, 2016 06:50 PM
mitsubishilover
Lancer Tranny/Drivetrain Tech
Apr 14, 2016 01:53 PM
ChefJMB
Jul 13, 2013 10:13 AM
W_evo8
11
May 27, 2009 07:59 AM
