Fluidampr hitting timing belt cover
Things are never "bolt on". It was easy enough getting the factory crank pulley off, but when tried to install the fluid amps, I noticed it wasn't sitting flush on the timing belt sprocket. After trying a few different things, I realized that it's hitting the timing belt cover where it puckers up to keep fluids out of the timing belt area. Looks like I'm going to have to grind off about 1/16" to get it to clear. Is this normal?
Here is a pic of the underside of the stock pulley and the Fluidampr. Stock pulley as a groove for the lip while the Fluidampr does not. Seems reasonable that they intended the Fluidampr to clear but probably just by a hair. Any irregularity in the t-belt cover shape causes the pulley to hit it.
stock pulley
Fluidampr
stock pulley
Fluidampr
Sorry to bring this back up but I've just installed the fluidampr on my built Evo yesterday. The install seemed straight forward, only issue is that it’s making a light whining\humming noise during cruise, but only between 2,000 - 2500 rpms. No noise at idle or above 2500 rpms. Is that normal? It was hitting the lower timing belt cover also, so I had to trim it a little but the noise is still present. Any suggestions?
Mychailo
I probably asked before, what did you feel/not feel after the change/upgrade to Fluidamper?
94AWD video recorded the engine sound-pitch change, speculating that when it revved up it was smoother and zippier...
Its an item on the list, looking for validation.
Mychailo
Interesting.. I'll need to double check mine once the new oil pump pulley goes on. I haven't ran mine with the fluidampr yet but it seemed to go on without any issue. However, I did not inspect the back side of the pulley.
