ARP bolt fitments
Old Dec 21, 2013 | 11:38 PM
jason42003's Avatar
ARP bolt fitments
So I was looking at rebuilding my had this spring with new cams, springs, valves, all the goodies. I know that the ARP flywheel bolts have fitment issues on the evos but what I was wondering was if anyone had used their other bolts (not the headstuds, giving that job to the map headstuds) but like the cam tower bolts, balancer bolts, exhaust bolts and possibly eventually the cap bolts on the bottom end (depending on if the shop that built my engine put the parts they said they did in. I'm just trying to avoid spending the pretty penny for bolts that will end up just like the flywheel bolts if I can avoid it. Thanks for the input.
Old Dec 22, 2013 | 12:00 AM
GotWheelHop's Avatar
The only bolts you need to upgrade are mains/head/rod. The rest of the bolts, OEM works just dandy. Torque things to spec and you'll see what I mean. The cam cap bolts are a perfect example. The proper torque is so low, you literally couldn't fatigue the OEM hardware. As for the balancer bolts, torque them to proper spec with a tiny dab of loctite, and never worry about them again. There are numerous 700-900hp evos running around with non-ARP hardware on engine parts, mine included.
Old Dec 22, 2013 | 12:39 AM
jason42003's Avatar
I know they will do it, and I know they are overkill, but isn't that the name of the game. Especially with the relatively low goals of 450 that I'm trying to push I just want to build the car once and it 10-15 years give it to the kid and it still be as good as the day I finished the build with proper maintenance.
Old Dec 22, 2013 | 06:36 AM
michaelrc51's Avatar
I did it on my rebuild. I put ARP cam tower bolts, cam gear bolts, balancer pulley bolt, exhaust studs, and IM manifold kit (I think). All of my internal stuff is done as well. I have to agree with the post above, they aren't necessary except the internal stuff.
Old Dec 22, 2013 | 10:25 AM
TommiM's Avatar
This.
Especially for something like the cam tower bolts that aren't torqued a whole lot, I would rather trust in the oem hardware imo. If your concerned about the bolts just replace with new oem bolts. I think even if the price was close, I would rather go with new oem cam tower bolts vs arp-- if I had to replace them.
Old Dec 22, 2013 | 10:29 AM
todd6027's Avatar
waste of time doing the rod bolts
Old Dec 22, 2013 | 02:34 PM
jason42003's Avatar
Thank you Michael exactly what I needed to know.
Black_EVO_MR
Jun 3, 2016 08:37 AM
varner88
For Sale - Cars For Sale
38
Dec 28, 2010 06:34 PM
Dragking2189
21
Sep 6, 2009 04:03 PM
TTP Engineering
73
Mar 7, 2007 03:18 AM
Spooldyou
Dec 17, 2006 08:57 AM
