which valve springs for high rev/boost
Old Feb 25, 2014 | 04:16 PM
420a-t's Avatar
Gents,
I'm currently building a 2.2 stroker motor, and should have everything back from the machine shop next week. Looking to see what valve springs I should order. I've been looking at MAP beehives with ti retainers, kiggly springs (both sets), supertech, and the GSC springs (not sure which ones though).
My block was re-decked and I'm going to probably have my head redecked as well.
-4g63 block, 94mm eagle crank, Manley tt rods, Manley 2.1l 10.5:1 pistons, stock head with regular sized valves, S3 cams with I believe 11.7mm lift, stock mls headgasket.
Which springs will work? What do I look at specifically when seeing if a specific spring will work with my cams/setup?
Thanks
Josh
Old Feb 25, 2014 | 04:17 PM
EvoDan2004's Avatar
i have run kiggly beehive springs for 5 years without any issues. they also have great customer service. kiggly for life here.
Old Feb 25, 2014 | 04:36 PM
poon'dEVO's Avatar
Kiggly Beehives here as well. Curt Brown hooked it up. They work flawlessly!
Old Feb 25, 2014 | 05:03 PM
michaelrc51's Avatar
Things you need to take into account are are how high rpms are you going to run and what boost level.
Make sure the lift is high enough to accommodate the lift of your cams with out retainer to seal contact. This can vary depending on headwork.
I have GSC5041 and they work fine for me. There are 2 different kingly Springs so you need to make sure you pick the set that will work for you.
Old Feb 25, 2014 | 07:25 PM
420a-t's Avatar
Thanks guys. I figured kiglys would work, I was wondering what else is out there that would work well.
Im planning on a 6466 or super 94 amd 35-40lbs probably
420a-t
26
Feb 22, 2017 11:49 PM
EvolutionIXMR06
118
Oct 27, 2015 01:52 PM
CtSilver03Evo
116
May 6, 2012 07:53 AM
My03evo
Feb 22, 2012 09:47 AM
Steve@NoLimitmotors
Evo 'For Sale' Engine Internals and Drivetrain
Jul 30, 2007 02:00 PM
