Car wont start after using wrong map?
So I accidentally started my car on my e85 map when I had 91 in the tank.
It ran super rich for a few seconds then I shut it off. Now it wont start on the 91 map.
Could too much fuel of just got into the cylinders and it needs to evaporate?
yes, sounds like you totally flooded it. try letting it sit for a little bit then starting it. or if you really don't have the time to let it sit. you can pull the fuel pump fuse/injector fuse. hold the gas pedal down and crank the motor (hopefully blowing out most of the flooded fuel in the cylinders). then go back and install the fuse and try starting.
mrm95
16
Aug 25, 2015 10:26 AM
