Fresh motor eating bearings
Old Mar 14, 2014 | 03:35 PM
04slowevo's Avatar
Nope will have it all cleaned when I do it this time. Didn't think about that when I installed new bearings, Shavings probably everywhere.
Old Mar 14, 2014 | 06:14 PM
wreckleford's Avatar
The sandblasting is a no no.
Old Mar 14, 2014 | 06:32 PM
WikdEvo's Avatar
who sandblasted anything?
Old Mar 14, 2014 | 07:25 PM
Originally Posted by tones61
did you have camcover sand blasted?
This guy mentioned sand blasting and the owner replied:
"Nope will have it all cleaned when I do it this time. Didn't think about that when I installed new bearings, Shavings probably everywhere."
Could have implied to someone that sandblasting should have been done, so I was clarifying that it was a no no.
Anyways, like everyone else said, that damage is from trash still in the engine.
Old Mar 15, 2014 | 03:23 AM
04slowevo's Avatar
Thanks
Old Mar 15, 2014 | 08:57 AM
TommiM's Avatar
Prob delete it to get it all running and then buy one later.
That's what I did on my rebuild. This way if there are any issues, its one less item to purchase again. Once you know your internals are good, then you can slap on the cooler.
Old Mar 15, 2014 | 01:24 PM
CO_VR4's Avatar
Make sure the oil passages are cleaned, as well as the pump, if you don't replace the pump and front cover. The contamination came from somewhere -- either the clearances were not right on your new motor, or it came from one of the parts you reused without cleaning them. The turbo can be contaminated as well as any oil line that was used when the engine failed the last two times… clean every oil passage, every line, and replace the cooler...
Old Mar 15, 2014 | 05:41 PM
ReidFletcher's Avatar
Clean/replace everything that oil touches. Have the machine shop hot tank the head. Replace the oil pump and cooler. Look into replacing the turbo as it will probably take a dump soon.
Old Mar 15, 2014 | 07:19 PM
batty200's Avatar
Don't forget to use assembly lube and then I always prime new engines with the oil pump and a drill before I install the timing belt. This way you know there is oil everywhere.
Old Mar 15, 2014 | 07:30 PM
meckert's Avatar
Check all bearing tolerances with plasti-gauge--dont take the builders word for it Make sure you have the rt size bearings as well. Lube and repeat..lol
Old Mar 15, 2014 | 07:43 PM
04slowevo's Avatar
Thanks for all suggestions. Will def take them into my next build with crank I'm getting.
Old Mar 26, 2014 | 02:26 PM
BogusSVO's Avatar
I would guess the crank was not properly cleaned.
Over the years crud builds up in the dead end of the oil galley.
Remove the press fit oil galley ***** from the end of the rod throws and clean it out.
WikdEvo
May 26, 2015 09:33 AM
WikdEvo
Jul 27, 2014 12:18 PM
WikdEvo
Jun 10, 2014 08:50 PM
WikdEvo
May 9, 2014 12:43 PM
WikdEvo
Mar 31, 2014 05:06 AM
