spun a bearing ? plz help
Old Mar 26, 2014 | 12:03 PM
ProKiD's Avatar
hi.
my car started making this knocking sound around 3.000+ rpm after few hard pulls, hitting a rev limiter nearly each gear
around 3000k miles on built 2.0 buttom end, hks 272 cams, 6262, pumpgas.
oil used valvoline race 20-50 for a break in, then switched to mobil one 10-30 synthetic oil.
any input is appreciated.
Old Mar 26, 2014 | 12:22 PM
Faisalm's Avatar
What's your rev limiter?
Also, that mobil 10-30... I though people were advised not to use it because of it's low viscosity IIRC.
It does sound bad though, hows your oil level?
Old Mar 26, 2014 | 12:30 PM
ProKiD's Avatar
i think it's set at 8000 RPM. oil level is fine. drained oil, nothing suspicious , checked cylinder compression all show 150 even idk. guess it's time to pull the oil pan
Old Mar 26, 2014 | 12:45 PM
Ev0ikon's Avatar
Time to drain and inspec the filter for metal flakes. Sorry man.
Old Mar 26, 2014 | 12:48 PM
Faisalm's Avatar
And next time please use oil with a higher zinc content in it Brad Penn 20w-50, Valvoline VR1 20w-50, something like that
Old Mar 26, 2014 | 12:55 PM
ProKiD's Avatar
yea prolly has to do with oil i used.
Old Mar 26, 2014 | 01:03 PM
SSGSXR's Avatar
Time for a rebuild and high compression.
Old Mar 26, 2014 | 01:11 PM
Go_Lancer_Go's Avatar
Should you run that on stock block, non-built?
Old Mar 26, 2014 | 01:12 PM
PS... who built your motor OP?
Old Mar 26, 2014 | 01:29 PM
ProKiD's Avatar
by me just had some local machine shop here in Austin Hone/balance/Polish/assemble my short block. pulling the oil pan will see what i can find. at this pont, im pretty sure my oil choice and driving ruined this motor
Old Mar 26, 2014 | 01:32 PM
ProKiD's Avatar
it made almost 500 whp and 400 trq on 23-25 psi on pump gas
Old Mar 26, 2014 | 02:23 PM
Faisalm's Avatar
You don't have to but it's a safety factor issue. FP will not warranty your turbo (if you have one from them) if you use oil with low zinc content. This is how a huge impact oil choice can have on the durability and reliability of parts that require lubrication. In other words, use a heavier weight oil (20w50) with higher zinc for your own benefit.
Old Mar 26, 2014 | 02:29 PM
Ev0ikon's Avatar
This one works fine too... for me anyways.
http://www.walmart.com/ip/Mobil-1-Hi...l-5qt/17034353
Old Mar 26, 2014 | 02:30 PM
I just figured 20w50 on a stock built motor is really heavy for stock clearances. Heard that oil is like honey
Old Mar 26, 2014 | 02:34 PM
mdsevo06's Avatar
No, a stock block has tighter tolerences and should run 10-30, and adding a higher zinc oil will help. ZROD 10-30 is a great choice for stock blocks.
20-50 is recommended for build motors with more tolerence.
