evo9 maf sensor
Old Mar 28, 2014 | 10:35 AM
vitalisevo9's Avatar
been searching a lot and its the same scaling on same part numbers... 05 and 06 evos used 399... if the car been tuned to different scaling then ya gotta retune.. or if it been on speed density... im sure if car not been tuned and put like 402 maf or etc then it will throw a check engine light on.. the o2 sensors and maf play together.. upstream o2 sensor can make minor corrections to air/fuel mixture... but ill stick to the 399..
Old Mar 28, 2014 | 11:15 AM
jrainwater's Avatar
I have a 399 with 40k miles on it in perfect shape if you want it for really cheap. I just happen to have an extra and I'm going to be going to SD next month so I really don't need this extra one. Next month I will have another one that I don't need lol.
Old Mar 28, 2014 | 12:00 PM
foxbat's Avatar
Evos 7/8/9 of all markets have the same MAF part# (MR578399) & the same scaling in the rom. The scaling is a set of estimated load values to interpret the electrical signal (HZ) coming from the MAF. It has nothing to do with the turbo or engine sizes. However, as jarinwater mentioned, intake & induction would affect maf readings as the factory scaling values were calculated with the stock intake in mind.
Old Mar 28, 2014 | 01:46 PM
jrainwater's Avatar
I was speculating that different Evo models might perhaps have different scaling for the same part number but its nice to know that they all have the same scaling. I suppose they all have the same stock air box and accordion tube intake so that makes perfect sense when you think about it.
Old Mar 28, 2014 | 02:32 PM
hey.. thanks for reply.. jrainwater.. send me pic.. ill take it off your hands long as its good working condition... comes with the screen right?? or pm me thanks
Old Mar 28, 2014 | 02:35 PM
once i find oem air box, fmic, uicp, licp, and so forth then dont think ill have problems... but gotta find some parts :/....
EvoEi8ht
Dec 29, 2015 04:34 PM
Hi Im Vinh
Sep 25, 2015 11:01 AM
jack of all
Aug 7, 2013 06:14 PM
AustinB768
Jul 21, 2012 02:12 PM
tyang85
Jan 5, 2011 10:51 PM
