add one to the jacked tranny list
Old Mar 10, 2004 | 03:52 PM
  #121
timzcat's Avatar
Originally posted by budlong
they basically said, "blue clutch voids the warranty" so even if its not my fault, because my clutch has blue, they will not honor the warranty.. that the hurdle i have to get past..
r u a mechanic btw? if so id like to use your opinion when i speak to mitsu again..
Yes I am. I have an associates degree in automotive technology that I obtained while in the General Motors ASEP program and worked as an A tech for 9 years total at Chevy and Saturn. I also have other various classes after college.
Old Mar 10, 2004 | 03:54 PM
  #122
timzcat's Avatar
Originally posted by Mister2zx3
That pic is of 1st gear on the bottom ( just a small bit) , 2nd in the middle and 3rd on the top right?
Your right on both counts. The reflection on the gear tooth of third threw me off. Those chips in the gears are sometimes normal and without knowing if they are in every tooth it's hard to say whether they are normal or not.
input shaft gears are small for low gears and big for high. Output is opposite.
Old Mar 10, 2004 | 04:00 PM
  #123
timzcat's Avatar
this is final outcome:
clutch assembly with OLD flywheel plus labor: $368
clutch assembly with NEW flywheel plus labor : $688
so its gone down from more than $5000 to no more than $700
the mechanic is supposed to tell me if the flywheel is damaged or warped... still waiting for his call....
it sucks i have to go thru all of this, but i was defintly worth it.
bastards
This is definitely good news. I know they don't want to pay for any clutches at all so I never expected a big turn around on that. The transmission on the other hand is now right. I think they know of a batch with some issue and swallowed thier pride and said "yeah it's really our fault"
The flywheel is probably not warped or anything and could be resurfaced. .005 would probably clean it up to like new and that little resurface would not translate into lose of travel.
Old Mar 10, 2004 | 04:06 PM
  #124
USP45's Avatar
budlong, I have to say it looks like you have handeled the given situation very well, cogradulations. You were absolutely correct to go in there with a calm demenor and calmly state your case. I do not think that things are out of line at this point, and I would go ahead and replace the clutch disk while they are doing the rest, might as well do it now while everything is apart even though your old one is not yet worn out. I am glad that everything was taken care of and happy that Mitsubishi came around to recognizing an inherent problem. It makes me feel better to see them take some responcibility in this matter, especially as I have an early build date car as well! I am already having problems with the shifting at higher RPM's ,6400+, and seeing them take care of problems is nice.
Old Mar 10, 2004 | 04:17 PM
  #125
jcnel_evo8's Avatar
Major F&&&@#$ rant!
Ok...
It was really, really, really good to see some pics of the clutch and tranny.
Now...the good part.
WTFFFFFFF are the techs thinking about leaving parts of your tranny 'lying' around!!!? Do they want to repair it and have things put back together, only to wear and tear some more, and BLAMO another tranny failure?
Here were some of the things I didn't like:
1.) Shift fork assy. Lying on the floor?
2.) Shaft and gear assy. Lying on a bare "metal" bench, probably uncovered.
3.) Misc. bolts lying around. Come on people, Glad tupperware for $10.00 for a CASE of these things WILL keep little parts clean and organized!!!!! $10.00 in organization = $1000.00 saved by both customer and dealer alone.
I really h8 dealerships that think they are somehow 'better' than tuner shops and general purpose mechs. just because they ARE a dealership. The only thing they have sometimes is a bit more electronics and a engineer that actually designed something 'maybe' avaliable.
BTW I really hope you end up paying NOTHING for all of the service they do. The clutch looks like standard DSM high output wear and tear. The flywheel has some surface varnish that heated, but the disk itself doesn't have any intense and noticable 'bluing.' Bluing to me looks like 1/4 or more of the disk just cooked altogether, and the clutch plate like a melted chocolate cookie. I'd resurface the flywheel, and go on with life.
Good Luck,
I hope the tranny gets put back together 'correctly.'
Later,
jcnel.
  #126
evolver's Avatar
Well, it's not the perfect resolution, but certainly acceptable, right?? It's too bad that you had to go through all that just because of the dealership. But, I'm glad you got it taken care of! Just remember how they treated you if you have the opportunity to refer, or if you have another problem with your car!
Old Mar 10, 2004 | 05:53 PM
  #127
budlong's Avatar
this will be the master technicians first evo transmission build supposedly he has done other mitsu's but that doesnt make me feel better. Im expecting troubles
Old Mar 10, 2004 | 07:44 PM
  #128
timzcat's Avatar
Manual trans are so easy to put together. As long as he usees the shop manual for all the settings it will be fine.
As far as parts all over the place it's no big deal as long as he plans on cleaning them before reassembly. I always stripped them down completely in a big pile of parts and cleaned them then put it all back together.
  #129
Mister2zx3's Avatar
Whats so wrong with the flywheel it can't be turned? if it even needs that? What does the stock clutch disk cost anyways?
Old Mar 10, 2004 | 09:23 PM
  #130
budlong's Avatar
thats good news
Old Mar 10, 2004 | 10:00 PM
  #131
SoR's Avatar
SoR
I have a question for the more technical guys - do you think that his tranny (in the current state) would actually drive on for much longer and that beside some notchiness it wasn't a big deal?
Also, is he allowed to collect his old clutch after the replace or does it go to the mother mitsu for inspection?
It looks like they are not doing any warranty work on the clutch.
I assume since they are asking to pay for the clutch you are allowed to get the old part back.
Reason asking is because I have a gut feeling they will just put the same clutch back in (since it's good) and charge him for it.
Good luck Budlong!
Old Mar 11, 2004 | 07:33 AM
  #132
slt's Avatar
slt
I'm curious too. I've got to take mine in for the 5th gear grind and thought it would be a good idea to throw a new clutch in since they will have it all taken apart. $400 seems kinda steep though.
Old Apr 4, 2004 | 10:29 PM
  #133
JohnEurostar's Avatar
03 Evo with 6400 miles. Same exact thing. I'm putting my money on the the throw-out bearing. There have been other recorded instances where clutch defects have been apparent, most recently with the S2000. Mine's definitely not getting worse (at least I don't think) but its been apparent since very early on. I don't see how it can be anything else. I'm reminded of my old 85 928 with the small diameter double disc clutch. It was and is extremely precise to match and install, frequently resulting in what I describe as a whine, grinding noise, or chatter.
I'm reluctant to go to Mitsu because I've burnt my clutch a few times getting accustomed to the no-wheel-spin take offs. I don't abuse my car. But having said all this, I'll be an SOB if some B-tech or schmuck service writer is gonna play judge and jury while some other regional rep shows up just to say "uh, sorry but there's evidence of 'abuse' on your vehicle." I have my own lift so one day I'll take the unit out myself.
CantStopSpinin
13
May 10, 2010 04:55 PM
GSXRolla
Jan 31, 2008 08:12 PM
jbrown
19
May 9, 2004 07:23 PM
TwoMix9900
Apr 14, 2004 08:21 PM
Thoe99
13
Aug 4, 2003 02:57 PM
