will Manley 156mm rods and stroker pistons fit?!
Great forum here guys the best anywhere really.
Ok my question i have a Tomei 2.2 stroker would Manley 156mm rods and stroker pistons fit in my setup?
Tomei specs are 85.5 bore 94mm stroke 150mm rod length.
I read English racing once saying they like long rod which is what this would be. But will it work for me? Are there any long rod setup out there did any encounter any problems?
Thanks everyone
Thanks everyone
Thanks everyone
Thanks everyone
Thanks everyone
Thanks everyone
there are plenty of nice 2.2 pistons being made. but I think all of them are for 150mm rod.
mahle, aries, cp, je, manley, all make 2.2 pistons
to use stroker piston designed for 100mm stroke you need either 153 or 159mm rods.
Has anyone done it before or know anyone that has and made it work?
The Tomei 2.2 is actually 2158cc not sure if that's classed as 2.1 or 2.2?!
Do you think this would work in my current setup of 85.5 bore 94mm stroke and 150mm rod length?
This is from a Tomei 2.2 stroker kit. But I want to run long rod for Lil bit more Rev so trying to figure out if i can straight swap the current h beam rods with the Manley i beams as I've heard the good for over 1000 hp.
Cheers
619005c -4 uses 94mm crank and 150mm rods. if you used the 156mm rods the piston would be above the deck by 6mm.
and you arent going to gain any revability by going to 156mm rod. how high a engine can rev is determined by the piston weight and rod strength and airflow at high engine sppeds.. making rod longer just makes rod heavier. it does reduce side loading by 2-3% but that has no effect on how high the engine can rev, venders talk praise on their 'long rod" setups but in reality they do very little if anything to help the engine rev higher.
I have those same pistons .020 over from Manley. They will work with a 94mm crank, 4g63 block, 150mm rods, and those 2.2l pistons (they are actually classed as a 2.1l on manleys website)
what rods did you go with? Any suggestion on rods to make reliable 800hp atw all day everyday?
Can I run the 153mm rods not dissimilar to English racing short long rods worth these same pistons?
I went with some Manley turbo tuff rods for my build. I wanted a motor that had good response off boost (hence the 10.5:1 comp and 2.2l), and could still rev high enough for a 9 sec. pass and make 800whp. This motor encompasses everything I want to do, and you don't have to buy custom rods with it. I also found a good deal on the rods and pistons so everything else kind of fell into place.
