will Manley 156mm rods and stroker pistons fit?!
I went with some Manley turbo tuff rods for my build. I wanted a motor that had good response off boost (hence the 10.5:1 comp and 2.2l), and could still rev high enough for a 9 sec. pass and make 800whp. This motor encompasses everything I want to do, and you don't have to buy custom rods with it. I also found a good deal on the rods and pistons so everything else kind of fell into place.
Can you do us favor please.can you double check your part no for those Manley pistons. Mine are pistons part no 619005c. Thanks
156mm rods and piston we be 6mm above deck at TDC
153mm rods will be 3mm above deck.
159mm rods will be 9mm above,
162mm rods will be 12mm above
see a pattern?
only 150mm rods will work.
Ok Thanks 94AWDcoupe I guess I'll start researching on those 150mm rods
SBR INC
Evo 'For Sale' Engine Internals and Drivetrain
12
Oct 4, 2009 08:42 PM
