ATP GTX3076R vs CBRD BBK-B BB
Old Apr 2, 2014 | 03:12 PM
  #46
IzzyRS's Avatar
O.P. how long do your turbos usually last (the way you race and drive)? Just wondering.
Old Apr 2, 2014 | 03:19 PM
  #47
Pure EvoIX's Avatar
CBRD BBK Full (JB) lasted 2.5yrs.
CBRD BBK B (BB) lasted 10 mo.
This is only for me. YMMV.
Old Apr 2, 2014 | 09:14 PM
  #48
sparky's Avatar
Originally Posted by 94AWDcoupe
I thought this was zhongs car we were discussing. have you seen his signature?...you are way to quick to rid TS from a track car. huge mistake from where I am sitting....
Is it really a huge mistake from where you are sitting? Wow, I will be sure to check with you first before posting from now on. My father passed away a few years back, so it is a relief to know that you are out there watching over me.
Old Apr 2, 2014 | 10:11 PM
  #49
94AWDcoupe's Avatar
so what I cant post my opinions and observations? dont post if you cant take criticism.
Old Apr 3, 2014 | 07:07 AM
  #50
sparky's Avatar
Undoubtedly you are correct, '94! ( :
Old Apr 3, 2014 | 08:28 AM
  #51
sparky's Avatar
I just got the impression from watching the OP's in car video and from his expressed desire to increase top end power that the 3B's compressor just isn't moving enough air for his engine starting from the upper-midrange on up through the top of the powerband. Hence his search for a different turbo, the ported throttle body as well as the MAP3 intake.
He has stated his observation that the 3B's turbine side is too restrictive and creates/contributes to problems such as excessive exhaust back pressure and the resultant high EGT's, high combustion chamber temps and high peak cylinder pressures, etc.
The ATP GTX 3076 does not seem like it would offer a complete solution. Compressor flow is probably about the same on that as a Red , which moves about as much air as his current turbo. Sure he gets rid of the restrictive MHI 10.5 housing but he will inherit the ATP housing which are generally considered to be restrictive in their own right. So, as someone else pointed out the proposed turbo swap will be at best a lateral move.
Old Apr 3, 2014 | 08:55 AM
  #52
nemsin's Avatar
A lot of the e-opinions surrounding the ATP housing seem to be based on very old information. I would love to see some testing/reviews of the CURRENT ATP offerings. It seems to me that they have revised their product line quite a bit since the early days. Not saying they are tops, but I think their products are probably not getting a fair shake on evom.
Old Apr 3, 2014 | 10:22 AM
  #53
sparky's Avatar
Repeat post.
Old Apr 3, 2014 | 10:32 AM
  #54
sparky's Avatar
Originally Posted by nemsin
A lot of the e-opinions surrounding the ATP housing seem to be based on very old information.....I think their products are probably not getting a fair shake on evom.
Yes, granted I am passing judgement based on ATP's older designs. They may very well have improved turbine inlet flow numbers through their new castings. Point well taken.
Old Apr 3, 2014 | 10:37 AM
  #55
sparky's Avatar
Sorry again...
Old Apr 3, 2014 | 12:10 PM
  #56
Pure EvoIX's Avatar
I agree, except the last paragraph regarding the ATP housing. Need latest data on that to really know instead of old prior information on the older version ATP products. To be fair to them. But yes, a slight lateral move, but an inch higher, with the "bigger than oem housing"
Old Apr 3, 2014 | 12:11 PM
  #57
Pure EvoIX's Avatar
Agreed. Hence why I made this thread seeking more information on the ATP GTX3076R.
Old Apr 3, 2014 | 12:17 PM
  #58
nemsin's Avatar
Maybe see if ATP could provide you (and us) with any info regarding their housings. If they have positive things to say I am sure they would just at the chance to get the word out.
Or better yet, take the plunge and post up some results for us
Old Apr 3, 2014 | 12:24 PM
  #59
TheShodan's Avatar
Originally Posted by xXANCHORMONXx
I was having the discussion with another person in the Bay Area as I was looking at the bbk-b since my full just blew.
I think oiling is a huge issue for road racing. I think the bbk b is great but can still get starved due to lower oil pressure in the head.
I have a fp green on the way with the required oil filter housing feed line. ATP was a close second and if this one fries I will go with the ATP for a couple reasons.
Cooling is a big thing, as well as less back pressure over any stock frame turbo.
One things I've found while researching atps stock location turbos is that they can run at higher boost with ease without the risks with a stock frame bbk such just blowing hot air.
Also if anything goes wrong atp is around the corner in Hayward.
If I bought one I would need to find out what restrictor it will need since I would want to feed it oil from the oil filter housing for sure.
You will also have a small increase in lag.
you will simply need a 7/16ths .030" restrictor fitting for that cartridge. It is the same used on the standard GT(X)3071R, GT(X)3076R, TR3030R and the GT(X)35R series. They come in -3AN as well as -4AN setups. I typically have them made for me and several others. especially for those that still want to run a -4AN inline oil filter from the oil filter housing to the turbo.
In transient use for the circuit, lag will be minimal, but slightly increased. better final drive gearing and certain specific boost controllers can assist with that.
Old Apr 3, 2014 | 12:30 PM
  #60
Pure EvoIX's Avatar
If it helps any, here are some images.
