ATP GTX3076R vs CBRD BBK-B BB
Old Apr 10, 2014 | 11:22 AM
  #121
sparky's Avatar
Originally Posted by 94AWDcoupe
I think....either the 7670 or 8374 in the 94 t4 housing is the hot ticket for time attack.....
Yeah, the A/R on that hotside should be loose enough to mitigate back pressure issues and being TS it should still spool really well on his stroker motor. Since it is integrally gated he avoids the cost and added complications of sourcing, flanging and plumbing for an external gate that he would have to deal with if he were to opt for the non-gated 1.05 housing.
Old Apr 10, 2014 | 11:58 AM
  #122
mrfred's Avatar
you can fill the ports with jb weld. plenty strong for the application. and can be burned back out if you wanted to reverse what you did.
Really? I would have thought that the heat cycles would cause it to debond from the aluminum.
Old Apr 10, 2014 | 02:53 PM
  #123
Pure EvoIX's Avatar
Originally Posted by sparky
I agree with you '94 that the 250(minimum)RPM loss in spool on the FP housing is pretty lame. In fact, I am depressed because my 3B has the ported anti-surge compressor cover and that reputedly robs another couple hundred RPM in spool.
I am either gonna order a stock MHI comp cover from CBRD cut for the BBK wheel(damn the surge!), or I'll weld up(fill) the surge ports and retaper the compressor inlet area removing the step down transition making it conical internally.
won't that void your warranty with CBRD...
or are you in the school of thought..."what warranty...what's that?"
Old Apr 10, 2014 | 09:41 PM
  #124
Benja's Avatar
I'll hopefully have more results to add shortly as well.
EFR7670, 0.92 T4 TS IWG.
Built 2L, S2's, stock intake manifold etc.
Old Apr 10, 2014 | 10:34 PM
  #125
Grimgrak's Avatar
Wow Geoffs pre 5krpm power looks like it's trying to spool a brick... Even mivec wont make that diff up...
I think RT has something in his setup that is holding it back. should have spooled faster and made more power. but I do think either the 7670 or 8374 in the 94 t4 housing is the hot ticket for time attack. look at geoffs 8374 numbers on 2.0. imagine larger displacement.
https://www.evolutionm.net/forums/ev...vs-7670-a.html
Old Apr 11, 2014 | 05:40 AM
  #126
94AWDcoupe's Avatar
I use epoxy to make runners smaller on intake manifold. years of alky injection and gas stains later its still in place quite nicely.
rc guys use epoxy to fill ports on two stroke cylinder. we're talking cylinder wall where rings ride.
Old Apr 11, 2014 | 08:12 AM
  #127
211Ratsbud's Avatar
Yup, thanks, JB Weld it is
According to certain video I saw comparing bullet surge ports to other style ie garrett, the bullet style is inferior: what I mean to say is if that is so I would not expect a detectable gain in spool. I will be ordering my next turbo sans surge port aswell however. I have an fp 84mm intake that I wonder how hard it is missing from that. Didn't er test this to find hit in spool and increase in top end?
Why doesn't anyone clip a wheel any more? It would seem that if you're above the boost threshold that it would be minimal penalty to response.
the efr stuff appears to be a gold standard of sorts but a) cost is substantially higher b) can't get your hands on them at all. C) not likely to fit a Garett kit due to packaging.
Old Apr 11, 2014 | 09:56 AM
  #128
mrfred's Avatar
I would have never guessed. So JB Weld is the best?
Old Apr 11, 2014 | 06:17 PM
  #129
sparky's Avatar
Originally Posted by Pure EvoIX
won't that void your warranty with CBRD...or are you in the school of thought..."what warranty...what's that?"
Warranty, what's that? You described my mindset exactly. Especially with turbos. I absolutely ring the **** out of the little buggers. I like extremely high levels of spring preload which equates to consistently high turbocharger shaft speeds. My motto: "It can NEVER spool too fast!"
I settled for a used 3B purchased from Chad. I originally wanted a BB BBK-Full, but I didn't have the spare change to order a new one. Being used I didn't bother to ask about a warranty. It seems to have a bit much shaft play....so we'll see how long she lasts.
I am not afraid of the JB Weld on aluminum either. My buddy bought a set of used Champion aluminum heads for his Buick GN. We discovered that one of the milled head gasket mating surfaces on the head had a low spot on it. It was about .250" low in one corner. He built it up with JB Weld and milled it down flat. He ran a 10.2 at 32 PSI at Sacramento with it no problem.
Pure EvoIX
Apr 7, 2026 12:16 AM
KOOLER
14
Nov 7, 2017 08:03 AM
evokun
12
Aug 3, 2014 05:41 AM
veilside prius
Feb 21, 2013 07:21 PM
hydra
30
Nov 23, 2011 02:02 PM
