factory ignition timing
Old Mar 6, 2004 | 06:49 AM
hotrod2448's Avatar
Question factory ignition timing
Does anyone know what the factory ignition timing should be @ 4000 rpm? The dealership here doesn't even know and any help would be beneficial. My best guess would be around 32 degrees btdc. sound right?
Old Mar 6, 2004 | 09:09 AM
992gnt's Avatar
Under what load? Just cruising (neutral throttle) you may see timing that high, but under full throttle timing would likely be around 10-12 degrees.
Example, when staging at the track I see 40 degrees of timing at 3988 rpms - no load. The lowest rpm I see during the run is 5210 which is right after I launch and I see 22 degrees of timing. After each shift, rpms drop to ~5600 rpms and timing drops to 10-12 degrees and climbs to 22 at redline. HTH.
