2005 MR over boost problem
Old Apr 14, 2014 | 04:49 AM
8mr331's Avatar
I have a basically bone stock (turbo back exhaust) 2005 mr with the factory boost gauge, when in 6th gear at WOT I noticed that the gauge read the full 1.5 which is about 23lbs? Is this normal, I always thought peek boost should be around 19lbs. Thanks in advanced.
Old Apr 14, 2014 | 04:52 AM
evo8426's Avatar
1.5 kg/cm2 is 21psi
Old Apr 14, 2014 | 04:54 AM
evolve_VIII's Avatar
6th gear is very tall causing the highest load on the engine. (its a highway crusing gear) It is normal to see higher pressures in this scenario. I wouldn't recommend doing 6th WOT pulls.
Old Apr 14, 2014 | 05:49 PM
adriano_917's Avatar
Thats a big no no! You want to say hi to your rods or what ?
Old Apr 14, 2014 | 10:20 PM
codgi's Avatar
Originally Posted by evo8426
1.5 kg/cm2 is 21psi
This and the stock gauge isn't super accurate. Also if you weren't the Original owner its possible the car's tune was messed with before and it was set to boost more than stock.
Old Apr 15, 2014 | 03:51 AM
8mr331's Avatar
What's a big nono? Over boost or 6th gear pulls ?
Old Apr 15, 2014 | 08:40 AM
egis's Avatar
Wot in 5th or 6th gears.
MRev
22
Aug 24, 2018 08:53 PM
Hotsht94
For Sale - Part Outs
Dec 6, 2015 10:53 PM
slammedndirty
Jun 22, 2015 05:17 PM
Viegasjuice
Oct 3, 2014 07:56 PM
dtkb87
147
Jul 19, 2014 10:13 AM
