idle issue with video
Old Apr 21, 2014 | 05:58 PM
N3WBI3's Avatar
ill let the video do the talking.
most recent mods are gsc s2s and e85
tuner also replaced throttle body shaft seal
Old Apr 21, 2014 | 07:48 PM
lostsoulsevo's Avatar
I had the same issue, front 02 sensor was going bad
Old Apr 21, 2014 | 08:08 PM
chamelieon's Avatar
mine is kinda doing that now.. im going to mess with it and see what gives..
you can put your idle on open loop and adjust the fuel via the fuel map and its pretty solid with this method, but of course it might mess up cold start and such until the car is fully warmed up..
Old Apr 22, 2014 | 02:37 PM
N3WBI3's Avatar
oxygen sensor is a year old, think it went that quick?
Old Apr 22, 2014 | 02:38 PM
N3WBI3's Avatar
deleting egr this weekend and checking for a boost leak too
Old Apr 22, 2014 | 02:43 PM
N3WBI3's Avatar
did yours throw a code?
Old Apr 22, 2014 | 04:13 PM
Yes the code would come and go until I replaced it. It could be a number of things though. The latencies could be off or you could have a voltage issue. Looks like the AFR's start swinging when fan kicks on.
Old Apr 22, 2014 | 04:52 PM
N3WBI3's Avatar
yeah i don't have evoscan or anything to look into the parameters. voltage issues sound scary.
Old Apr 22, 2014 | 05:53 PM
Try to get someone to log it on evoscan
Old May 5, 2014 | 11:16 AM
detroit pistins's Avatar
Any updates on this?.....Did the oscillation begin when you the made switch to E85?
Old May 7, 2014 | 06:16 AM
N3WBI3's Avatar
No updates. When you look at the maf when logging it just jumps from 35 to as high as 61 hz for no reason. Was doing it before e85 but not as bad
Old May 7, 2014 | 07:23 AM
is your PCV valve still on or was that deleted?
Old May 15, 2014 | 06:57 AM
Any updates?
bluedub1
Aug 31, 2013 05:35 PM
vassili
Oct 13, 2010 11:06 AM
TurbotrixRacing
Turbotrix Racing - Edison, NJ
14
Oct 12, 2009 07:33 PM
