Engine failure.
Old Apr 28, 2014 | 03:11 PM
2006EvoIXer's Avatar
Am I seeing the pu tures right? The contact area on the piston is on the dirty side?
Old Apr 28, 2014 | 03:22 PM
How does the wear look under the piston (connection to the rod)?
Old Apr 30, 2014 | 04:45 AM
GeoMitsu's Avatar
From underneath the piston is like new identical to the others.
Old Apr 30, 2014 | 06:44 AM
Faisalm's Avatar
Did you get your rod checked?
Old Apr 30, 2014 | 04:37 PM
evolve_VIII's Avatar
What about the oil squirter not cooling the piston properly? Maybe its clogged...
Old Apr 30, 2014 | 11:25 PM
GeoMitsu's Avatar
The rods were checked and they are Ok and so is the oil squirters.
It's a mystery......
I even checked before dismanteling the engine the oil pressure:
@ idle 0.8 bar
@ 3000 revs 3.7 ~3.9 bars
Old May 1, 2014 | 07:20 AM
You may not be able to notice an oil pressure difference with a clogged squirter or bolt. I think the spring rate in the bolt is around 45psi. Did the car have a turbo failure before? Maybe something got into the cylinder between the piston and wall causing them to touch.
Jun 9, 2015 08:49 AM
duan2309
Aug 26, 2014 09:24 AM
jspecteggy
Aug 19, 2014 11:49 AM
Royal Evo
Apr 28, 2014 03:10 PM
evo9felix
Mar 26, 2014 02:23 PM
